Baf.2050. - Office Equipment & Supplies
My hp deskjet 2050 output tray open error
fata error during installation in hp deskjet 2050 printer
hp printer not uninstalled .
how to uninstall driver hp deskjet 2050
Jun 07, 2013 | HP Deskjet 2050 All-in-One Printer
Pairing Problem - BluetoohJabra VBT2050 & LG Shine CU720
I have a Jabra VBT 2050 bluetooth headset. As per the product user manual(page 8) this device is compatible with any bluetooth mobile phones with bluetooth version 1.1 or higher.
My LG Shine CU720 mobile phone is not able to detect the VBT 2050 device. I checked the specification of mobile phone & its bluetooth 1.2. I am able to pair the VBT 2050 with other bluetooth mobile devices.
Could you help me resolve my problem. Appreciate quick help
Apr 01, 2009 | LG Shine 720 Cellular Phone
Kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
How do I put a Jabra VBT 2050 into discovery mode?
OK, this is what you do: 1. Make sure your Jabra VBT 2050 is fully charged. 2. Enable bluetooth on your phone. 3. Turn on your VBT 2050 with the little button on the side (the white light between the keys should flash). 4. Initiate a search from your phone while holding down the center button on the VBT 2050 (middle, under the + and -). 5. You might need to do another bluetooth search using your phone (it took me about 4 times befor my Blackberry Storm picked up the signal. 6. When your phone asks for a code, type in 0000 (the default number).
Jan 10, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
14 people viewed this question
k24674
jasbo
jasbo
