Question about Proton MM2701VT 27" TV
Samsung DLP TV Powers Off by Itself
I have a 43" Samsung DLP Tv and it just started to power itself off. It will not power back on unless I unplug the power from the wall. Then I plug it back in and it works fine for about 3-5 minutes then shuts-off again and i have to go through the same routine.
  • 1 more comment
  • Anonymous Nov 05, 2007
    I have exactly the same problem with a Sharp 25K S100 TV. It will reset after unplugging the set from the wall, only to turn off a few moments later.
  • dberkus Jan 18, 2008
    I have a Samsung 5566W that just began doing the same thing randomly. Powers itself off after 5 or 50 minutes. Will restart with remote only to do it again randomly. Manual says: "Watch the three lights on the right for clues to whether it could be lamp, heat, vent blockage. But the lights that do light upon involuntary poiwer-down don't match anything in the manual. Frustrating. Need advice...
  • michelleaalb Oct 31, 2008
    I also have the problem on a sharp 52" tv-no rhyme or rhythm to how long its on before turning off-sometimes if I unplug it once it stays on indefinitely, sometimes for only a few seconds.
Yes i have the same problem i need help
Posted on Jan 31, 2009
SOURCE:
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Samsung HLP5063W looses picture, turns off wont turn on and more
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
Jan 23, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
I have had this Samsung DLP HL-P 4663W for about 3 years now.
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung dlp HL56A65 turns off and on by itself
    It looks power board problem.
    You need to get service from Samsung.
    Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung DLP4663W
  • Oct 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
    Samsung HLS4266W 43" dlp
    Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
    Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
    Samsung 46" DLP
    HLP, HCN HL-S The Start-up Problem or/and
    3 LEDs in the front blinking.
    Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
    Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
    Proton MM2701VT 27" TV Logo
    525 people viewed this question
    Top Proton Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
