Question about Dryers
Eziload 4kg Where does the tensioning spring go on a 4kg eaziloader? Mine has come off when the belt broke.
SOURCE: Dryer won't start, Simpson Eziloader 4kg
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
Posted on Jan 25, 2008
dmftrucker
  • 1922 Answers
SOURCE: dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Posted on Jul 30, 2009
  • 93 Answers
SOURCE: how to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Posted on Aug 29, 2009
SOURCE: I have a simpson eziloader dryer modal 39S500 the
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Posted on Jul 02, 2010
  • 3074 Answers
SOURCE: impson Eziloader 4kg, drum will
I believe there is a capacitor on your motor(7-10 MFD) I would replace this and then ensure that the drum is reversing properly. It is usually just a short 2 to 3 turns, and the "normal" direction is much longer. This is done via a small motorized unit, usually called a "MOTOR TIMER", and the contacts inside it can get a bit burned an pitted if running for a while with a deteriorated start capacitor. If the motor and drum seem OK, but it does not reverse, you might need to change that unit. More expensive dryers might have a timer relay for this, or an electronic timer activating the relay.I hope this helped Tim
Posted on Feb 05, 2011
Blades stopped mowing, still runs. What's the issue?
Most likely your belts either came off the pulleys or broke also tension spring may have broken or disconnected ,,with the engine shut off check the main drive area first..then follow back to the deck..if the Belts are in place with the blades engaged check for tension..if none the tension spring or worn belts is the problem..good luck.
Aug 22, 2015 | Garden
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
How do I remove the altinator belt and replace the supercharger with a new one? just so you guys know... MINE IS DONE FOR NOSE BROKE AND BEARING CAME OUT AND ITS SEIZED. PLUS PULLEY BROKE IN HALF.
Sorry to hear that. Few people know the supercharger has its own oil. It needs to be checked and refilled as the car ages.
There is a spring loaded belt tensioning device....you need a socket that fits the bolt (some have a square hole for a 1/2 breaker bar) you take the tension off the belt and slip the belt off the most convenient pulley.
Oct 24, 2013 | 1995 Buick Riviera
Where does the spring belt tension go on my simpson ezi loader dryer??? I was replacing the drum belt and it flicked off and I didnt see from where. A picture would be good.
the motor is spring loaded - move lift motor towrards the cabinet lining to the right. Put band around drum and pully at rear of motor then allow motor to move back onto band to cause the tension
Feb 17, 2011 | Dryers
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
Broken main belt.
Aug 29, 2009 | Dryers
Dryer will not spin
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Belt tensioner promlems
your truck should have a spring tensioner pulley that keeps the belt tight. on my 96 with the 5.7liter 350 the spring broke inside the tensioner and needed to be replaced.
hope this helps!
Feb 28, 2009 | 1991 Chevrolet K1500
Dryers Logo
21 people viewed this question
Top Dryers Experts
