Question about Vehicle Parts & Accessories
How 2 bypass 03 rx8 transponder security - Vehicle Parts & Accessories
Can i bypass the ignition safety lost key 01 ford escape xlt
Sorry you can't. Ford's suck because you have to have two keys to reprogram the security to the keys. Last one I had done cost about $200. Dealer only.
Nov 29, 2015 | Ford Cars & Trucks
Where are the black and red wires connected from the prestige aps787c remote car starter two wire yellow plug 2 pin transponder control output? i will also be using the dbal2 bypass module. thanks
The only 2 pin connector is for the transponder bypass module.
These wires are for the following outputs
2 Pin Transponder Output Harness #1123292
1) Red Battery (+) 100mA
2) Black (-) Output While Running 100mA
This connects your transponder key module to the starter, it activates the module when cranking to simulate a key.
a: When selected for while remote start on, the Black wire will be active at the same time ign. 3 becomes
active, and will remain active all the time the unit is operational under the control of the remote start.
b: When selected for output during the start sequence, the Black wire will be active at the same time Ign.
3 becomes active, and will remain active until the vehicle has started. This will be used for one time read
transponder circuits.
c: When the unit is selected for until ignition off, the Black wire will become active at the same time ign.
3 becomes active and will remain active even after the key take over and until the ignition in the vehicle is
turned off. This will allow the unit to be used for continuous read transponders circuits
Nov 14, 2014 | Prestige Remote Start
What do you need to install Avital - 2-Way LCD Remote Start with Security to a dodge magnum 2005
A security or transponder bypass.. there are a few different companies that make them.
Sep 25, 2013 | 5303L 2Way LCD Remote Start Security...
Transponder for 2006 mitsubishi eclipse for remote starter
Yes, There are two Immobilizer bypass modules on the market that will work with your vehicle without having to sacrifice a key. Xpresskit offers the DBALL and PK9. Both require programming to function properly.
Sep 08, 2012 | Remote Starter with Keyless Entry
My 2003 Tahoe runs great, but the security light on the instrument panel stays lit when the truck is running. It does shut off when the key is off and doors are locked. What's the problem??
The security light is an indicator for a failed antitheft system. This is ALL it is for. NOTHING else. If the light is on and you are experiencing no adverse effects, you are probably alright. My guess is that the system failed, and somebody bypassed the antitheft system. (poorly) This would cause the light to be constant and the vehicle to run normally. (assuming you bought this used)
Here is a cheap way to see if the system was bypassed.
Go get a copy made of your truck key. Will cost a couple bucks. The original key has a Transponder hidden in the plastic head of the key. This transponder is a needed part of the antitheft system. The new key will NOT have this transponder. If it turns fine and starts the truck like normal, then your truck is bypassed and problem is explained and solved. If the new key turns but the truck will not remain running, then you are probably on the verge of a security failure, indicated by the security light.
Also make sure the original key is nowhere near the vehicle when you try this out. You dont want the ignition reading the signal from the original key while trialing the newly copied key
This link explains the SECURITY issue more.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 08, 2011 | 2003 Chevrolet Tahoe
Try to start my 06 rx8 with car starter and only my dash lights go on then shut of 3 times without my car turning over. The key port is also locked.
It sounds like the bypass module is not bypassing. The next time that you attempt to remote start the vehicle, look at the cluster for a flashing key. If there is a key inside a car flashing...your bypass module is not functioning.
Nov 29, 2010 | Remote Start System
It starts and runs, than shuts off 3 seconds later? i havent tried anything yet, and it was installed in 2002. jeep grand cherokee.
Do you have anti-theft system bypass module installed? Transponder key bypass? Try unlocking the doors with your factory Jeep remote (turns off alarm) and leaving the gray transponder key in the ignition cylinder. Then try activating your remote start. Sounds like one of the factory anti-theft systems is still active. Basically if the car's computer doesn't want it to run, the car won't run. You have to fool the car into thinking it is OK to start and stay running without the key and anti-theft device deactivated. You need to leave a transponder key in the vehicle under the dash to bypass that system. You can get a generic one for about $20. You MUST have 2 original gray transponder keys in order to program a third. There is a sequence of putting one key in the ignition, then the second, then the new blank key so the cars computer knows to allow that key also. If you do not have 2 original keys, then you need to go to someone that can program properly like dealership or some locksmiths or alarm shops. Then they usually charge about $100 for a second key. You don't have to have the key cut. That way if someone finds the spare transponder key in the vehicle, it wont turn the ignition cylinder. The anti-theft bypass module (factory alarm bypass) runs about $25. Bulldog Security or JBS model 791 should work for your vehicle. If you live in an area where car thefts are common, you may not want to bypass these factory security measures.
Hope this information helps.
Nov 02, 2010 | Prestige Remote Start
Does everything but will not start car
what is the make year and model, you may have a transponder key and will require a bypass module
Jan 16, 2010 | Bulldog Remote Starter & T-Harness Kit for...
I installed a prostart remote starter with a universal bypass transponder. it cranks but will not start.
put your key in the ignition hole and remote start it, if it starts you need to reposition the key in the box or the loop around the igntion switch
Jan 08, 2010 | Bulldog Remote Starter & T-Harness Kit for...
Chrysler Voyager Sentry Key Immobilizer System Problem
If your key is grey, and you would like to bypass the transponder system you need 2 working keys to program it, this kit comes with a bypass box, and a transponder loop, and only has 2 wires to hook up. Let me know if you still need to bypass it
Apr 21, 2009 | Chrysler Sentry Key Immobilizer Bypass for...
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
