Question about Sansui HDPDP4200 42 in. HD-Ready Plasma Television
Can i connect an antenna to this tv - Sansui HDPDP4200 42 in. HD-Ready Plasma Television
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I had a TV amplifier Channel Master 3042 I need to know how to connect it
This amp can be used with an off-air antenna or a cable box (up to channel 141).
With an antenna: Connect your antenna to the input. Connect the output to the tv's RF (antenna) input (if you're only driving one tv from this amp), or a splitter (if you're driving several tv's).
With a cable box: Connect the feed from the cable company to the amp's input. Connect the output to the input of the cable box.
Nov 13, 2014 | Audio Players & Recorders
No antenna port for Olevia TV How do I connect outside antenna to Olevia monitor
you will have to use a VCR, DVD player that has a built in tuner, or an HD converter box. The HD converter box will have an antenna connection for the outside antenna. But will also have RCA outputs to connect your TV to the converter
Feb 05, 2013 | Olevia 237T 37 in. LCD TV
I plugged antenna in but I still can't install channels problem is that I cant choose "channels installation" option maybe because tv is on video mode but I can get it to normal mode...
Antenna?? If you connected an antenna to the TV, you can only picking up radio waves. In the TV's menu options you should have a connection selection to choose from "Cable" or "Air". With an antenna, Air needs to be selected. Go through your "Input" selector from tv remote and select "TV" which is always the first selection. If this does not help, let us know exactly what is connected to the tv whether it be a COAX cable alone, a coax connected to an antenna, or if you have rabbit ears connected.
Jun 30, 2010 | Televison & Video
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Don't know how to connect my vcr to my tv
You can either plug RCA cables from the audio and video, audio is red and white for stereo or just one of them for mono, the video is yellow, from the "outputs" on the VCR to the matching colors on the tvs "inputs". You can also connect the antenna output on the VCR to the antenna input on the tv and put the tv on channel 3 or 4, if done this way connect the antenna/cable to the VCR antenna in and connect a cable from the antenna out to the tv.
May 27, 2009 | Televison & Video
Do I need an antenna on my sony model # KV35S45 TV when I cancel my cable?? If so, where is the antenna connection on the TV?? I can't find one. Thanks.
YES! the antenna will plug into the same spot the cable wire is connected too ( you may have to buy a adapter for $1.00 for the the antenna wires to connect to back of your set available at any wall-mart or radio shack) And since your switching to antenna you will need to buy a digatil converter box in FEB to get antenna TV!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Sony KV-35S45 35" TV
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Sansui HDPDP4200 42 in. HD-Ready Plasma Television Logo
23 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
