Question about Tools & Hardware - Others
My Benchmark 1072-172 Heavy duty stapler won't fire staples. What might I do to get the stapler to work?
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
  • 23 Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
Posted on Mar 22, 2009
  • 384 Answers
SOURCE: how do i load the Desa Powerfast heavy duty
Turn Stapler over.
Posted on Aug 06, 2009
Hugh fulton
  • 62 Answers
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
  • 454 Answers
SOURCE: can't load staples in high capacity stapler
Try breaking off about 15 staples from the strip.
Posted on Dec 24, 2009
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
How do you load a ace heavy duty clipper stapler model number 82?
I found some information here:
ACE STAPLE Quality Tradition for Over 50 Years
It takes the Clipper Undulated Heavy Duty 3/8" Staples. On the back of the stapler, there is a loading rod. Remove the loading rod and place a set of staples in the chamber, then re-install the loading rod.
Dec 02, 2015 | Heavy Duty Tools & Hardware - Others
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
What size staples for a Cobra heavy Duty stapler?
Take it to home depot or lowes, they will sell you the right ones.
Feb 22, 2011 | Arrow Fastener 8000 Cobra Heavy-Duty...
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Oct 06, 2008 | Stanley Heavy Duty Stapler, Cast Aluminum...
Tools & Hardware - Others Logo
114 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
