Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Front panel controls are unresponsive
TV was operating normally, turned off, then when daughter turned back on, switched to Video 2, sound maximized, and none of the controls on the front panel work. TV can't be turned off, even after pulling the plug. When you turn the sound down, it automatically turns itself up to max. I can't change from Video 2 to any other video input. I removed all the connections from the TV and plugged into a different outlet and the behavior followed. Any insight is appreciated!
    New Friend:
  • 76 Answers
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Posted on Sep 06, 2007
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Sep 17, 2007 | Nintendo NES Console
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
Not responding to remote , automatically changing to AV1 , AV2 ..PC ..ect.
First you have not indicated the brand or model but that aside the issue appears to be a bad micro switch or the keyboard with the controls on this set, I would suspect the source or TV video button first, not the plastic button itself but the tiny switch it activates, that is bad---have someone get at that and disable or remove that and the set should again function in a normal way.
The micro switches are momentary and should only operate when pressed, the problem is they fail, and with no one pressing the switch activates on its own.
Dec 11, 2012 | Televison & Video
Black screen with Green letters indicating Static Mode? All buttons on the front ov TV are unresponsive? Except for OFF
Static would indicate a lock up exists.
If you had a power outage it will cause this.
UNPLUG SET FOR TEN MINUTES AND PLUG BACK IN AND SET SHOULD RETURN TO NORMAL OPERATION.
Mar 15, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Maxim 11-54 26 inch lcd tv switch mode power supply blown up need new one
I have a Maxim 15" Portable LCD TV with built in DVB-T Tuner.
It has worked well for 2 years.
Now when you switch it on set to DTV
Starts to reload the channels
Once it has found 90 channels it moves to Add and will not add any.
There are no stored channels from the built in freeview.
However we still have the normal 4 on ATV.
Any advice.
Aug 10, 2009 | Televison & Video
Menu Screen pops up, try to exit and goes to video 1
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 27" wont turn off!!!!
It looks like one of the buttons on the front panel is stuck, base on the info you have provided; the volumen down button is stuck. The remote or any other buttons will not be operative until the fault has been remove.
I would suggest to try to press the Vol. down a few times just to see of it unlocks, if that does not work, the front panel assembly will have to be remove and try again if it works with the remote or manually.
The last thing to do if none of the above works, it will be to put a new switch.
Good Luck.
Feb 20, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
