Question about Brother P-Touch 1180 Label Printer
How install laminated tape/won't feed
My brother p-touch has been printing labels on laminated tape just fine, now all of a sudden it won't feed the label. I didn't install the tape the first time, so I need to know how to re-install or where to place the end of the tape so I can see if this will fix the jamming. Thanks
  • Anonymous Nov 17, 2007
    laminated paper became jammed and was not feeding out. I unjammed the paper but now im not sure how to reload into machine.
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
Ajkill
  • 2035 Answers
SOURCE: label sheets won't feed, jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
komguy
  • 2306 Answers
SOURCE: Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Posted on Aug 28, 2009
komguy
  • 2306 Answers
SOURCE: Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Posted on Sep 17, 2009
bwag01
  • 3 Answers
SOURCE: Brother P-touch 1180 tape cartridge jammed
Man, that tape's a real b!%^ch. I just spent an hour figuring it out, so here ya go... In the center is a (larger that the rest) gray wheel, this is the "toner" take up reel. On the tape that's come out of the cassette, seperate the three layers, and start "reeling in" just the toner. (The laminate and label that have come out are just lost, no real hope for them) When you get close to the end of the toner, help it feed straight back in, and it will go all the way back in. You may have to hold on to the laminate and label so it doesn't try to follow the toner. once that done, it should look like the original cartridge, trim off the excess and you should be good to go.
Brian
Posted on Apr 01, 2010
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
I need help to change the tape on my p-touch 55 brother labeller
Hello. here is the owner manual http://www.ptouchdirect.com/ptouch/manual/PT55.pdf
Just look at the section entitled "installing/changing the cassette tape". Regards, Joe
PS kindly rate my answer. Thank you.
Jan 24, 2010 | Brother P-Touch 1180 Label Printer
Brian
Nov 13, 2009 | Brother P-Touch 1180 Label Printer
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
BROTHER P-TOUCH 1100
My Brother p-touch 1100 is feeding the white tape through but not printing black ink on it.  It has a new cartridge.  Can anyone help please?
Jun 19, 2008 | Brother P-Touch (PT1100SBVP) Label...
Labels are not printing correctly
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Mar 11, 2008 | Brother P-Touch 2200 Thermal Printer
Brother P-Touch 1180 Label Printer Logo
414 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
