Question about Health & Beauty
Ohaus i5s manual - Health & Beauty
Cant see the numbers on ohaus ruby 300
Cant see the numbers ohaus ruby 300
Dec 04, 2014 | Health & Beauty
Ohaus ES50R ES powers tares to zero does not register weight
saya lupa password ID poker88, admin tolong segera bantu saya ya, hubungin ke no ini aj bos admin, 082156894135
Dec 05, 2013 | Ohaus ES50R ES Low-Profile Bench Scale
Ohaus scale won't turn on
Hi Bud, The unit has a built-in adapter which could be the problem but best to call Ohaus directly at 800-526-0659.
ED
Dec 06, 2012 | Ohaus Ranger Heavy Duty Compact Bench...
Need instruction manual for JR Ohaus 300 scale
The Operating Manual for the Ohaus 300 Compact Jewelry Scale may be downloaded here:
http://www.ohaus.ca/PU/PDF/IM%20RUBY%20EN.pdf
Jan 08, 2012 | JR Ohaus -300 Ruby Jewelry Scale, 300 x...
I dropped the box holding my Ohaus ruby series scale and now it only shows E. Is there a reset button or anything I can do to resolve this issue?
Sorry there is no reet button. Make sure the battery contacts are still making good contact. If so try to calibrate the balance. If that does not work the balance should be replaced.
Jan 30, 2011 | JR Ohaus -300 Ruby Jewelry Scale, 300 x...
I dropped my Ohaus about 3 feet onto carpet. Now when I turn it on it boots to the E screen everytime. Help!
I am an Ohaus technical specislist. I have unfortunate news. You scale is broken and there is no other way to fix it but get it repaired. You can send it to us at:
Ohaus Corporation
Atten: Service Department
7 Campus Drive
Suite 310
Parsippany, NJ 07054
Jan 02, 2011 | Ohaus CS200 Standard room Scale 200g X1g...
I have a Ohaus gram scale Model N06112 and all the read out says is error code 9.8 and is unresponsive to pressing any of the buttons????
Your problem may have a simple fix. It is called a manufacturing calibration. Unfortunatly it is a little too complicated to answer in this forum. If you will email techsupport@ohaus.com I may be able to help you.
Ohaus Technical Support.
Dec 18, 2010 | Life Science Ohaus Ya-501 500 X 0.1 Gram...
A part is boken inside the measuring cell can I get spares for a AS120 model? for the measuring cell?
Officially at Ohaus the AS120 is no longer supported.
The parts for a PA64 are available. Some of these parts are interchangeble with the older AS120 but I would not recommend an untrained person try to replace them. You can order the parts form Ohaus or any of our dealers. Please remember though all the parts for the AS120 are not available so if something is damaged during the repair it may not be available.
Nov 23, 2010 | Ohaus Analytical Balance Pioneer PA64
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
