Question about Electrolux JetMaxx Steam EL9000A
Electrolux steam mop
The power light is on, when I press the power button the heating light comes on. Normally It takes a minute and the Ready Light comes on, but it just stays on Heating. The mop is only 2 months old and has only been used 3-4 times.
SOURCE: Electrolux 2100 bag light stays on and power won't cut on
SRING CABLE
Posted on Nov 12, 2007
  • 15 Answers
SOURCE: electrolux power nozzle not working
FIRST OFF EACH OF YOU HAS A COMPLETELY DIFFERENT MACHINE. ESPECIALLY THE OXYGEN WHICH IS MADE BY THE "NEW" ELECTROLUX. THE OTHER TWO ARE MADE BY THE "OLD" ELECTROLUX WHICH IN NOW CALLED AERUS. THE ADVICE WITH THE GUARDIAN TO GET IT SERVICED BY THE DEALER SINCE THE POWER NOZZLE IS PROBABLY STILL UNDER WARRANTY IS A GOOD IDEA. (THE 25 YR. WARRANTY DOESN'T APPLY TO THE WHOLE MACHINE SO YOU HAVE TO READ CAREFULLY WHATS COVERED. THE MAIN MOTOR DEFINITELY IS.)
ASIDE FROM ALL THAT
DID ANY OF YOU HIT THE RESET BUTTON ON TOP OF THE POWER HEAD?!
Posted on Apr 10, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
SOURCE: 9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Posted on Aug 29, 2009
bento_daniel
SOURCE: I have a 2 year old Electrolux ergorapido cleaner
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Posted on Sep 12, 2012
My steam mop heats up and light is on, but the steam does not come out.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Mop is not heating/steaming. It was fine one minute but when plugged back in 30 minutes later it won't steam. Light is on and canister is warm.
heatman101
;s
Aug 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: shark steam mop has water, but there is no steam....
I tried running vinegar through as you would a coffee pot to get rid of hard water scales. This did not work. Then I noticed that the light behind the shark decal on the front of the machine was going off and on. And sure enough as I moved the cord around the light would come off and on. Looking closer I could see the the heat had melted thru some of the cord.I bought mine at Target before xmas last year, throwing away the sales slip after several months so I guess there is nothing I can do about it.
May 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam Mop is plugged in but does not heat up or the light does not come on?
heatman101
kk
Mar 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Plug in but does not heat up, no light on but
The thing just plain broke...
heatman101
Mar 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Blue light comes on mop but will not heat up
heatman101
Feb 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No power coming into machine
Hi All
Up Date on shark no steam no light.
The fuse that controls the steam is a thermal fuse, 192c ,10 am 250 volt.
Now that may sound strange to some one who dose not know fuses, but Radio Shack carries them and there $3 bucks!
If there is a handy person you know, they should have no problem replacing the fuse. I just fixed ours in about 30 min. but I work on electronics. If the Shark gets to hot this fuse will blow to prevent overload or fire so don't put bigger fuse in it!!
FYI you have to take All the screw out and open up the unit fuse is burried look for yellow clear film (thats the color mine was), the film is wrapping the fuse. Good luck
May 09, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Electrolux JetMaxx Steam EL9000A Logo
32 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
