CRT ULTRA SLIM
I am electronics repair man in Ethiopia. I have panda CRT 21" Ultra slim Tv. I have changed the board with new 21" universal board. But after a minutes the HOT become very hot & blown. I tried the board is on other 21'' normal tv screen. It is normal. Also I tried other tcl board on that Panda screen but the HOT become extremly hot. But when I replaced the yoke the screen function and no HOT become hot. But the geometry problem occured. I realize that the screen wants high yoke driver(HOT). The original board have FET ( IRF 630) that get an input from Y and support the Hot. Now my question is how I can build that ( IRF 630) Circuit externally to get HOT not blown? AKA I have changed the board bc the CPU 8373 have no response for key and remot. Every voltage in the board (110, 185, 25, 12, 9, 5) normal but the voltage out put for the RGB (R=1.3v G=1.3v B=9v) and 9v for Crt= 3v i.e no green and red colour. No tuning. But only blue screen. But the HOT is normal. I also changed EEPROM if the is child lock activated. Finally I have Changed the board. But it cant be a solution. Any one help me on the way I can fix either the original board, Or the New board fit with the yoke. Is that possible to use 2 or more HOT in parallel, As in that of audio power ampilfier stage?
Slinteriors
  • 8617 Answers
SOURCE: how to replace red crt on 52" RCA
When a red crt goes out and wont light its usually another reason such as a transistor or even faulty CRT pc board that causes it since the set powers up the other two tubes. Go to this link and leave them an email and list the model number and tell them the symptoms they will help you out with it, they are real good with the RCa sets. If the red tube was shot it would cause the set to go into shutdown or throw red retrace lines across the screen. Heres the link,
http://servicemanuals.vstore.ca/
Posted on May 21, 2008
  • 178 Answers
SOURCE: My CRT TV has false colours.
The set needs degaussed this is common issue, most tv's have a degaussing coil in them, but they are very weak and will not correct extreme issues. It is possible the internal degaussing coil has stopped functioning. If this is one of these sony 40" crt's this is a big problem. and any metal near by will cause gausing of these tubes. Have a tech come out and degause your tube. A technician will have a very powerful loop coil that will clear the problem with one or two passes. But if it returns, check for perminant magnets near the set like large speakers or any other thing, this can also be caused by a child;s toy with a magnet it it if the child has rubbed it across the screen. This is not a destating issue and can be corrected easly.
Posted on Sep 03, 2009
Testimonial: "Thanks Dude...It worked."
SD Tech
  • 14553 Answers
SOURCE: TV Screen went green, LG 21" CRT TV
The expert addressed no longer seems to be posting answers on this site.
I would suspect the trouble is one of two things---a shorted device like an IC on the board at the end of the picture tube---most sets use either 3 transistors, one larger IC or 3 individual chips---first thing is to examine the soldering on that board looking for any broken connections.
If you can find a schematic for the set voltage checks will pinpoint where the issue is---an old trick if uses 3 transistors or 3 chips is to identify which is green and swap it for one of the other 2 if numbers on them are identical.
Second and fatal possible reason is the green gun in the CRT picture tube is shorted---almost no way around that as the tube itself would have to be replaced---most modern shops are able to test the tube and determine if shorted or not.
SD TECH
Posted on May 03, 2012
gopakumarg43
  • 75581 Answers
SOURCE: LG CRT TV ULTRA SLIM THIS CRT TV SCREEN IS HALF& LINEARTY PROBLEM
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Posted on Jun 22, 2016
gopakumarg43
  • 75581 Answers
SOURCE: Lg tv strw6554a smps may I get the circuit diagrame .This is ultra slim CRT tv 21"
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" or the STR number of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Sep 30, 2016
Sep 30, 2016 | LG Televison & Video
Samsung CTV 21"ultra slim no light sound OK eht OK
maybe the electron gun had gone south? tube is dead? check with a technician to get full diagnosis. You may still be able to get part if a repair is needed
good luck
Jul 02, 2015 | Samsung Televison & Video
My TV display is gone only a shining line appeared. Volume is ok
Having had that problem myself with another brand I would say that either your CRT or Video board has gone out, The board can possibly be repaired but the CRT would need replaced.;
Jun 25, 2014 | Samsung SMC-213 Ultra Slim 21" CRT Color...
HORIZONTAL WHITE LINE ON THE TOP OF SAMSUNG ULTRA SLIM TV
My tv problem no picthire only retres line all screen no pannel opreting no remot work
May 12, 2014 | Samsung Ultra SlimFit 20" Digital TV
Lg ultra slim 21 tv sound picture power
ok ur tv powersupply is ok but horizantal is not working chk ur fbt hot & micronass
Mar 21, 2014 | Televison & Video
USB port not working in ONIDA Ultra slim 350 CRT TV
India ultra slim 350
21slp350bg
What is the remote number
Jun 27, 2013 | Televison & Video
How to fix tv turn off by itself
If the TV turns off by itself during working, there must be some fault with its main power regulator board inside. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 07, 2013 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Hi my tv is ultra slim fit.screen turns green from time to time with vertical lines.what's wrong with it?
hello, I think that problems occur because the connection that has been cracked. If you have experience in electrical, resoldering on the pcb crt and vertical ic area.
good luck.
Mar 24, 2011 | Samsung Ultra SlimFit 20" Digital TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
