The picture is smaller than the screen-Flat screen TV
I have a 46" flat screen TV and the picture is smaller than the screen about 10" on each side. I don't know how to fix it.
  • 1 more comment
  • Anonymous May 29, 2008
    I have a 26 in LCD flat screen Mintek DTV and picture is much smaller in width than the screen. Don't find any adjustments for this in menu.
  • shelbystar1 Nov 26, 2008
    Problem is: When playing DVD from PC, the Picture on my 46" LCD is much smaller than the screen size.
    Is there a setting available to fix this issue? Can the DVD menu be accessed through Media Player?
    (Windows XP - Media Player 11 - DVI output to HDMI cable input, 12 feet long)
  • angelo3696 Dec 17, 2008
SOURCE:
SOURCE: philips 37 flat screen
I bought a plasma Philips 42 inch model number 42PF7320A/37 also 18 months ago. The exact same thing is happened to us. The screen would go black every since we brought the tv after about an hour of watching it. Then the other day it went black and never came back. The red light in front is blinking and they are saying we need service!!!!!! A $2000 TV lasting 18 months. I am trying to get Philips to be accountable, I am very upset with this product.
Posted on Dec 23, 2007
  • 50 Answers
I'VE WORKED ON A LOT OF PHILIPS FLAT SCREENS AND ALWAYS NOTE ,WHEN THERE ARE PROBLEMS WITH THESE SETS--THE RED LED WILL BLINK GIVEN YOU A CODE FOR TROUBLESHOOTING..EXAMPLE---ONE L0NG BLINK,4 QUICK BLINKS--BAD AUDIO BOARD,,,SOOOOOOOOOOO,CHECK YOUR BLINKS,HA!
Posted on Mar 21, 2008
  • 4 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
  • 105 Answers
SOURCE: Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Posted on May 21, 2009
  • 197 Answers
SOURCE: sony bravia 46 lcd The picture dims and
set has a light sensor. go in menu and turn light sensor off
Posted on Jul 02, 2009
Model Le46M51B samsung flat screen TV clouding
sounds like your screen is separating. If you tv is less than $1,000 prob not worth fixing
Nov 15, 2013 | Samsung LE46M51B 46 in. LCD Television
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Televison & Video
Sled4668w tv scans channals but always shows 0 found hooked upto dish network
This Orion TV made by Sansui was bought by me two weeks ago. It didn't last a week. The sound was terrible, picture was great, and it wouldn't hook up to soundbar without hearing a long delay in sound (A/V or Digital output tried two). I contacted their customer support twice, they were awesome. Told me this model has know issues and said to just bring it back. I found another TV for same price ($399) and same size (46) but it's LCD not LED, better picture and great sound! It is Insignia don't remember the model #. Bought at Best Buy (their house brand).
Feb 22, 2013 | Televison & Video
Samsung 46 LCD has shadow on left side of screen when TV is turned on
I would to see a picture of what it looks like. What you are describing sounds like a faulty LCD panel tab. Samsung LCD panels are known for this problem.
Oct 09, 2012 | Samsung Televison & Video
I have a 46" flat
IS your image actually being cut off by the black bars? If not this may simply be the way the signal is being transmitted to your TV. One quick way to tell is to check to see if the image is the same on all channels, while watching a DVD, or playing a game. Alternatively, you might look for a Format button on your TV remote. This button may cycle through the picture formats available to your TV. See if pressing this button changes the picture dimensions.
Hope that helps!
Jul 18, 2011 | Televison & Video
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Apr 21, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
When we turn on our tv in the morning the left
Call Sony my friend. I have the same exact issue with the same model. They already have a recall for the 46"XBR4. Let Sony know that us 52" owners are having the same issue. I'm essentially calling them everyday until they fix it.
Mar 27, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
Televison & Video Logo
1,276 people viewed this question
Top Televison & Video Experts
Ekse
