Question about Garden
Murray mower 22516x92c
Starts..revs up then starts to die
  • 40 Answers
SOURCE: My mower surges. its a Murray, model number
first check to see if you have good clean gas in it. No water. if you have good clean gas. then I would recomend taking the gas tank off wich should have a plastic carburetor mounted to it. after that is removed and free of excess dirt. take the carb off there should be 5 phillips head screws. pull the carb off gently while observing just how it all goes back together. you may want to take pictures. you will find a fuel screen that you should take off and clean with carb spray. also there is a fuel pickup tube clean that also with carb spray. a couple words of caution if using compressed air Do not carried away with it. also same with the carb cleaner to much of it in rubber primers is not good.
Posted on Mar 11, 2009
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
  • 8 Answers
SOURCE: Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
Posted on May 25, 2009
  • 93 Answers
SOURCE: murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Posted on Sep 15, 2009
  • 18 Answers
SOURCE: murray 20 inch 4.75 push mower.trying to flood,only revs up when
01 Air filter might be filthy and restricting air flow calling for more fuel than necessary, especially if black smoke is coming from muffler. Supporting this is that you say it begins to run OK as it runs out of fuel.
Posted on Apr 20, 2010
Model 40808X14A. When blades are engaged, why does mower die?
Most likely something is jamming a blade.
Another possibility is the reversing safety switch is stuck which cuts the engine spark.
Apr 15, 2016 | Murray Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray 42506x92A (1998) 42" Lawn Tractor, starts easy, but surges and dies. Over and over... It acts like it is running out of fuel. I changed the fuel filter and spark plug, but no improvement.
Check the fuel bowl to see if anything thing is in it. If it has a auto shut switch on the bottom of the bowl, it may be the cause as well. Next check that the valves (ohv) are adjusted right.
Oct 08, 2014 | Garden
Murray 21hp/46
Sounds like a micro switch issue shutting the engine down, start by checking the seat switch, make sure the connecter is pushed well in.
Mar 12, 2012 | Murray Garden
Murray 20 inch 4.75 push mower.trying to flood,only revs up when
Apr 19, 2010 | Garden
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Riding mower having problems starting then runs roughly
I would bet you have a fuel problem. Either the carb is clogged and dirty or needs adjustment. Try opening the screw on the bottom of the carbuerator about a half turn see if that improves it. Also check the air filter and clean it.
Jun 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
