116-317 Xerox workcentre 7328 has an error code of 116-317 reboot, did all that still it does go back to the error.
  • 2072 Answers
SOURCE: Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Posted on Mar 28, 2009
  • 2072 Answers
SOURCE: Xerox WorkCentre 4150 Error code: 20-800/The
One of 2 things.
EIther you have to enter the Fax User memory, Or the memory battery has failed and needs replaced.
Here is what the service documentation says.
(4150) During a power-off period, the machine has lost its user memory. Check that the backup battery, PL 1.10 Item 5 is holding its charge of about +3V. If necessary, install a new battery, PL 1.10 Item 5.
Posted on Dec 29, 2009
  • 111 Answers
SOURCE: Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Posted on Apr 01, 2010
wrinaldo
  • 185 Answers
SOURCE: xerox workcentre 7328 fault code 062-393
This is a document scanner problem, probably a bad circuit board. (This PN may be 960K00442 but that needs to be verified in your unit)
Short of that, you could reinstall the "IIT software".
A technician could reseat the EEPROM on the IIT board which controls the document scanner. He should also reseat the scanner bar and cables underneath the glass.
Whit
Item, Inc
Posted on Oct 06, 2010
markandcandi
  • 3 Answers
SOURCE: My Machine Xerox Workcentre 7328
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
Posted on Dec 03, 2010
Xerox workcentre 7328 error code 024-365
The error code states: Overflow on Back Loop Write
Unable to find any definitive information about causes or resolutions. This sounds like a software problem, probably internally to the unit. You may want to try re-installing the computer drivers if it only affects certain user computers.
Mar 04, 2015 | Xerox Office Equipment & Supplies
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Error code - 001-302
check if the front cover is closed properly. If this doesn't work try rebooting the printer with the front cover open. Close it when it started up. Clean sensors. All not working. Engineer.
Nov 27, 2013 | Xerox WorkCentre 7328 Colour Multifunction...
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
My Machine Xerox Workcentre 7328 getting a fault code 062-393
Oct 20, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
49 people viewed this question
jasbo
jasbo
