Question about Tools & Hardware - Others
Where does spring that fell out of Boston stand up stapler go?
Spring fell out and don't know where it goes. One spring is still in the bottom. Two all together.
4 Suggested Answers
SOURCE: spring fell out of stanley tre500 how to put back
4-5 inch spring no good need new one.
Posted on Oct 30, 2009
SOURCE: my craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Posted on Dec 20, 2009
SOURCE: Spring on my Swingline POWER GUN 1000 is broken.
Junk it, peice of ****!!!!! Extra heavy duty and the spring is effin junk, throw it out!!!
Posted on Apr 19, 2011
Tr50 stapler loading spring fell out can I put it back in its nearly new maybe used 5 times
Reinstallation can be tricky. You have to be careful to avoid stretching the spring too much. That will weaken it.
Jun 10, 2014 | Stanley Office Equipment & Supplies
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Mar 03, 2014 | Stanley Black & Decker Bostitch 20SUITE...
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at www.surebonder.com on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
Mar 17, 2013 | Surebonder Pneumatic Stapler
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
Pt 3406107 fell apart. I need to know how it is wired to put it back together. It is the door switch that cuts off the dryer power when the door is opened. There is a small spring and a free standing...
if it fell apart Just get a new one and use the connector supplied with it ,, Once they give way they possess a danger better safe than sorry and the part isn't that expensive, heres the part for 16.00 and change !! http://www.partselect.com/PS346704-Whirlpool-3406107-Door-Switch.htm?inventory=346704&SourceCode=6
May 24, 2011 | Maytag Dryers
The spring has come out and we don't know where to put it
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Jul 01, 2009 | Stanley Staple/Nail Gun Elec
Safety B
Sounds as if you have a small Bostitch nailer/stapler. Bostitch lables its safety mech parts as Safety A for the part that actually contacts the work and Safety B for the part that contacts the trigger. Go to www.Bostitch.com and look for diagram of your gun. These two parts fit snuggly just behind the outer-most guide/nose. Safety b sits on top of safety a. There is usually a thumb adjustment and a spring between the two parts. The spring is usually installed on top of safety a and below the adjustment knob. enjoy
Nov 23, 2008 | Air Tools & Compressors
Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
Tools & Hardware - Others Logo
67 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
