Question about GE DSXH43EAWW Electric Dryer
Ge dryer dcl333eaoww timer
Ge dryer dcl333eaoww works but timer dont move
4 Suggested Answers
SOURCE: GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Posted on Jan 16, 2011
heatman101
  • 43501 Answers
SOURCE: have a GE Dryer model DCL333EAOWW that will not
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 06, 2011
  • 34 Answers
SOURCE: electric dryer GE, model dcl333eaoww, run for short time then stop, will run again when start again
ASK The Company only
Posted on Aug 23, 2012
Have a GE Dryer model DCL333EAOWW that will not turn on. Circuit breaker to wall outlet fine. Thought it might be switch behind 1/4 turn knob you use to turn it on. Replaced switch. Still won't start....
heatman101
Jul 29, 2011 | GE DCL333EA Dryer
Dryer does not heat
My GE (model #:DCL333EAOWW) Dryer does not heat up and the timer on the dryer does not work. Does anyone know what I would look for to fix this problem on my own?
Jan 16, 2011 | Dryers
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
Mar 06, 2010 | GE Dryers
Aug 14, 2009 | GE Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Automatic drying is not working on GE Mod DPSR473EW0ww. I assume sensor may be defective. where is it located.
timer is not turning and you still have some heat coming into the dryer??Remove the vent hose from the dryer for 1 load .Is the timer moving now??Your vent is clogged up. Please Rate This !!
Jun 09, 2008 | GE Dryers
GE dryer willl not stop, drys OK
I does sound like the timer has went out on your dryer, but there could be other problems as well.  Sometimes exccesive lint build-up can cause a heat transfer issue with the thermostats.  On GE models, anything o stop or delay heat transfer could cause the timer to stop working.  If im not mistaken, this is a gas dryer correct?  It could be a number of things that could stop the forward motion of the timer, primarily a stuck or inoperative thermostat, a defective flame sensor (highly doubtful if it dries), or a wiring problem.  Be sure to check out all your wiring, then if you wanted to, try and replace the thermostats.  Just dont want to see you waste a lot of money if it was a bad timer.
Oct 30, 2007 | Dryers
GE DSXH43EAWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
