Question about Hasbro Alphie The Learning Toy Robot
Wiring diagram for motherboard
Two wires are not connected to motherboard
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
I need wiring diagram for asus m2a-vm
these dont usually have a wiring diagram as there isnt much to wire just a few places that you need to connect the power switch and stuff too. so all you really need is the user manual showing you where to connect the stuff.. here is a link for it.. Its PDF and has everything in detail..
MANUAL http://static.highspeedbackbone.net/pdf/Asus_M2A-VM_Manual.pdf
it has powerwiring, usb etc.. enjoy
Mar 20, 2011 | ASUS M2A-VM (0610839149438) Motherboard
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
Hi.unfortunately I disconnected all wires from motherboard and on the end I have problem because I don't really know in which pin I should connect the power sw wire and reset sw wire
hi, heres a tip, you will need a diagram of your motherboard. if you have one, then you can start looking for the wires where it should be put. if none then you can search in the web for a diagram, you should know the exact model of your motherboard when searching for precise schematics.
Feb 23, 2010 | Computers & Internet
How to connect power sw and led and reset sw and hd led
You'll need to go to the Elitegroup website and download the .pdf file showing a diagram of the motherboard wiring layout and pin connections and then connect the wires from the case to the proper locations.
Oct 07, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Cannot connect usb on motherboard??? URGENT HELP
Have you searched the net for motherboard wiring diagram ... plenty available ... I recently downloaded one. There is only four wires to connect + , - , D+ and D- . Hope this helps.
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Wiring connections
Here is the website to find and download a manual which will have the wireing contacts on the board identified.
http://downloadcenter.intel.com/NotFound.aspx?NoMatch=rg82845e〈=eng#
Dec 29, 2008 | Intel Motherboard
Wiring
The user guide for the motherboard should have a full diagram for all the wiring you have. Here is the link: http://www.manualnguide.com/dl/8959/
Sep 10, 2008 | ASUS Computers & Internet
Hasbro Alphie The Learning Toy Robot Logo
29 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
