Question about Radio Communications
Imt521 pairing mode
It is not pairing, i'm using 0000 as PIN
SOURCE: Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Posted on Nov 27, 2008
EdNelson
  • 149 Answers
SOURCE: pin code for Altec Lansing
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
  • 215 Answers
SOURCE: i cant pair my nokia 6303c to my parrot incar set
It appears some Parrot models use 0000 but a number also use 1234.
Try 1234 first, but the link below gives user guides for a number of Parrot products.
See if your model number is listed, or scroll down and see if the pictures let you identify it.
www.parrot.com/uk/support/userguides/#MKi9000
Posted on Feb 02, 2011
  • 43 Answers
SOURCE: trying to pair em227 with
Try 1234 or 9999
Posted on Jun 13, 2011
HDI Headsets
  • 537 Answers
SOURCE: trying to connect bluetooth to
The pass code should be 0000 (four zeros), it's always been that for Plantronics headsets. Here are a couple of things to try. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Second, you want to reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and page 4 will walk you through the pairing process. Remember to remove any previous bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Posted on Nov 29, 2011
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
I can't get my HS850 in pairing mode
Hi Jeanie:
Hope helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 28, 2011 | Motorola Mobility HS850 Consumer Headset
I have had this bluetooth for a while but never used it. Trying to pair it With my new iPhone and dont remember having a PIN #. what do I do now? Or can I use it?
The default pass code is "0000."
Here's how to pair it with the default pass code:
  1. Turn the Bluetooth on and hold down the button until the light turns solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000"
May 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
If prompted, enter 0000 for the PIN code/passkey.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
I have a samsung phone and i am trying to pair it with my jabra vbt185z but i don't know the passkey...i tried using 0000 but that didn't work. so what else can i do to make it work?
You do need the passcode. It should "auto pair" but the default passkey or pin is 0000 (4 zeros.)
Here is a link to the user manual
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2010/Documents/UM/VBT185z_UM_6198.pdf
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
dw
Dec 31, 2010 | Jabra BT150 Wireless Headset
Pin code for Altec Lansing iMT521 SoundBlade BT Speaker to pair wit iphone 3gs
Dec 18, 2010 | Altec Lansing T515 Portable Speaker for...
My iPhone recognizes my Emerson 227 bluetooth but pin numbers will not connect using recomended codes 0000-1111-1234-9999 are there any other salutions my iPhone is 3g
Put the headset into pairing mode. First turn it off. Turn it on and hold the powerbutton down until the bluelight is not blinking then pair using 0000 as the pin.
Aug 21, 2010 | Emerson EM227 Bluetooth Headset
Oct 22, 2008 | Philips VOX120 Wireless Headset
Wep500
0000 is the default pin.
May 23, 2008 | Samsung Wireless Headset for...
Radio Communications Logo
35 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
