Question about Singer Stitch Sew Quick Sewing Machine
My singer stitch sew quick machine is missing stitches what should I do to fix this
Stitches are missing what should I do to fix this
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
bunnydawg
  • 5158 Answers
SOURCE: how to do all the stitches on my Singer fm-22-c
i'm uncertain if you have the manual so here it is
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/7442-_M
http://www.scribd.com/doc/3713782/Singer-7442-Sewing-Machine-Manual
it isn't simple to download the manuals but you shouldn't have too much trouble getting them either... be that as it may if you cannot download them from at least one of the pages i sent let me know
Robert
Please take a moment to rate this solution thanks
Posted on May 24, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Posted on Sep 02, 2009
  • 255 Answers
SOURCE: My sewing machine is not sewing stitches
That is irritating! Singer has your manual; check out: http://www.singerco.com/accessories/manuals.html
I believe it costs $15.00.
Happy sewing!
Robbie
Posted on Jan 29, 2010
  • 18 Answers
SOURCE: singer 5525 sewing machine knots
You can go here, search 5525, and download or purchase an instruction manual for your machine, if you have misplaced the one that came with it. It looks like there are some available as downloadable pdfs for free and some physical ones for $15. https://www.singerco.com/accessories/manuals.html
Also, Singer has just installed new Q&A features on their website. You can go here: http://new.singerco.com/products and look for your particular model or machine category. At the bottom of the product page, you can post Questions for singer experts and other community members to answer!
Posted on Jul 22, 2010
Hi I'm new to sewing! Does my singer have a blanket stitch
Your machine is a beginner model with only 8 stitches. Looking at the photo of the machine, it does not appear to have a blanket stitch.
Singer 1507 Sewing Machine
Usually, only more advanced (and expensive) machines with more stitches will have the blanket stitch.
Nov 08, 2015 | Singer 1507
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
All my decorative stitches are comming out straight
it sounds like something has happened to the cam gears that
do the decorative stitches, which means the sewing machine needs
to be checked..
but before you have the machine checked,, make sure all the
dial that are used for decorative stitches are at the right setting
one missed setting can cause a lot of problems
Nov 02, 2012 | Singer Sewing Machines
I have a Singer 327K that stitches three or four good stitches and then stops completely stitching
it's very possible that when the needle broke the machine went out of time & would have to be retimed at a sewing machine shop
Mar 10, 2012 | Singer Sewing Machines
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
Happy sewing!
Robbie
Jan 29, 2010 | Singer Quantum XL-6000 Computerized Sewing...
Singer Stitch Sew Quick Sewing Machine Logo
75 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
