Question about Garden
How do you adjust the carburetor on Ryobi chainsaw RY10520
  • 398 Answers
SOURCE: I need help with a carburetor adjustment on my chainsaw.
this site gives alot of helpful hintshttp://www.arboristsite.com/showthread.php?t=5208
Posted on Mar 02, 2009
  • 120 Answers
SOURCE: husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Posted on Jun 20, 2009
  • 4088 Answers
SOURCE: adjusting carburetor
Does saw try to run? Initial settings are about two turns out from CW stop. Set high speed (on warmed up engine) to 4-stroke with no load, but smooths out with light load (cutting wood). Idle is set for fairly smooth idle, but engine picks up with throttle without lag. Idle speed setting is somewhat below chain drive clutch pickup, but allows engine to keep running.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: what is the carburetor metering lever adjustment for an
Clarification Request
Posted by slohry on Apr 10, 2009
What kind of carburetor does it have? Zama, Walbro? And what model carb?
No response to clarification request... delete this question.
Posted on Sep 16, 2009
  • 4088 Answers
SOURCE: How do I adjust the carburetor on a Poulan 38cc
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Be sure to check the fuel filter, air cleaner, and muffler for plugging. Start the engine and allow to warm up--pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Proper adjustment is reached when the engine 4-strokes at speed, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 09, 2010
Ryobi chainsaw idles normal, when wide (full throttle) open the chainsaw surges. would this be a bad carburetor?
Sounds like the fuel filter is getting plugged up. Easy to replace and you should be able to find a new filter where ever lawn mowers and trimmers are sold. Put a hook on a piece of wire and the fuel filter can be fished out of the fuel tank with ease.
Oct 09, 2016 | Ryobi Garden
Could some help me with factory carb settings on this saw
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
tekindoor.com > MISC
Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
homeguides.sfgate.com > ... > Adjustable Mortgage Rates
The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
Dec 04, 2015 | Garden
Where can I get the limiter caps for the carburetor?
they sell special tools to adjust carbs yours may have a flat spot on it or splines all the way around them I never adjust with the plastic on them they just allow you to go so far hope this helps
May 11, 2014 | Ryobi Garden
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
My pcn 4545 chainsaw has started to over rev upon starting. The idle adjusting screw is backed off all the way and not the cause of the problem. Can you please tell me how can this be corrected and...
Remove the air cleaner and watch the throttle arm on the carburetor while operating the throttle trigger--suspect that the trigger assembly has acquired sawdust and dirt sufficient to limit proper travel of the trigger mechanism. Careful notes as you dis-assemble the trigger will help get it back together properly. There is little except proper maintenance to prevent debris accumulation in the trigger mechanism. Note: air leakage behind the carburetor can also cause high idle speeds--make sure the carburetor is fastened securely and that there are no flaws in the gaskets and heat insulator located behind the carburetor. Hope this helps!
Jul 13, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Carnt keep ryobi pcn 4545 running when i increse the power
How do you increase the power to an electric saw? By your question, I'm assuming a fueled engine model. Check the fuel filter, air filter, and muffler for any plugging. Check condition of fuel lines and tightness of carburetor fasteners. If no help, turn the H jet needle CCW about 1/4 turn--which should result in the engine 4-stroking. Will the engine now run at speed (but not as fast as before)? If ok, warm the engine up, open the throttle and adjust H CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces best power and least heat! Hope this helps!
Apr 26, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Nov 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Need to set L+H fuel mixture screws from scratch for chainsaw ryobi pcn3335 .been played with and now won`t start
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Sep 20, 2009 | Garden
Ryobi pole saw model ry52502
my Ryobi RY52502 starts but when i change the lever from start to run, it will shut off
Feb 03, 2009 | Remington 111409 - 01 6" Branch Wizard...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
