Question about Syntax SV266A SKA KT266A Motherboard
Fastest socket A processor?
I would like to upgrade my AMD athelon 1.73 Ghz to the fastest processor that this motherboard supports... Can you tell me which processor to buy for this socket A slot (probably used on ebay...) Thanks!
    President:
  • 2,961 Answers
I think you will find that you are in fact using the fastest speed processor for the socket 'A' type of motherboard as AMD has changed to socket 754 or 939 for dual core processors. You can clock the speed a little in the bios, if you go to the peocessor section in the bios and look at the clock speed probably set at 133MHZ you can move it up 1 increment at a time, eg 134MHZ and keep trying until the pc wont boot up, at which point you will have to reset the cmos settings JBAT1 terminal and then set it again to the fastest you got it to before it wouldnt boot.
Posted on Sep 01, 2007
SOURCE:
Upgrade processor
You have to now your motherboard.whithout that it is impossible to say.
Apr 06, 2013 | Dell Inspiron One 2305 Desktop Computer...
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Like to replace my processor which is AMD Duron 900MHz to Motherboard Gigabyte 7VM333M-RZ. Which current processors are compatible with this board? Please advise. I want a current fast processor.
Hi, As far as I can see, this motherboard is very old, and the faster processor you could get would be around 1.8 ghz, single core. Here's the list of supported processors:
http://www.cpu-upgrade.com/mb-Gigabyte/7VM333M-RZ.html
What I would suggest is that you buy a motherboard/cpu combo, then you could get a quad core with a recent motherboard for less than 150-200$. Of course you'd have to be willing to change your motherboard, but unfortunately, you're not gonna get a good processor with your current motherboard, and computer parts (like Ram, hard drives, video cards) are going to cost more and more for their rarety, while they are less performant.
Best of luck to you!
Mar 14, 2011 | Computers & Internet
What is the fastest processor I can upgrade for Gateway E-6000 ? I try to upgrade memory, but they r just too expensive
first check to see what kind of motherboard you have. then use google to search for that motherboard, and from there it should tell you the fastest-supported processor.
Feb 23, 2011 | Gateway E-6000 PC Desktop
I have a QDI KinetiZ 7b/e motherboard with a VIA VT8363A Apollo KT133A chipset (4GP 4x/2x for a socket A processor and an AMD Athlon 1.1 Ghz processor. Three SDRAM sockets each with 512MB. OS is Windows...
You are running the fastest processor that this board will accept. If you want to go faster, you will need to buy a new motherboard and replace it.
Semper Fi,
Z
Feb 20, 2018 | QDI Group QDI KinetiZ 7B Motherboard
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
Hello again, Upgrading CPU's
Your board supports socket AM2 CPUs the fastest of which is the AMD Athlon 64 X2 6000+ dual-core processor at 3.1 GHz.
Your motherboard does not accept socket AM3 CPUs.
Dec 15, 2009 | Computers & Internet
K7VTA3 v6.0 Motherboard - What Faster processor can I install
AMD Athlon XP 3000+(.13u) (512K,333,Socket 462) according to website
Dec 02, 2009 | EliteGroup ECS Motherboard MB K7VTA3...
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
Syntax SV266A SKA KT266A Motherboard Logo
251 people viewed this question
Top Syntax Computers & Internet Experts
Ekse
Robert Salgado
Robert Salgado
Eric Sutherland
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
