Question about Hitachi 43FDX01B TV
Color alignment there a bow like line on the bottom and top of my screen plus any words or images that appear on the screen have a visible shadow and the colors dont quite line up either
  • 398 Answers
It sounds like one of your convergence IC's has burned out and needs to be replaced. The defective IC will have to be replaced, the low-value resistors next to it checked and the convergence circuits realigned. If you do not have any experience working inside projection sets, allow a qualified tech to handle it for you.
Posted on Aug 31, 2007
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
There is a bow in the picture top and bottom of screen
The tv have a problems known as a convergence problems,it is dead.Tv have colors R,G,B lines mis alignments,have shadows pictures or 3D picture look alike?Yes the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replace on the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 09, 2011 | Apex Digital GB4308 43" Rear Projection...
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
I have a HCN4727w samsung. Red/green shadowing. Bowed image
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
I have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 43FDX01B TV Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
