Viore rc2001v original remote doesn't work anymore. replaced batteries
jdvillanueva
  • 2098 Answers
SOURCE: Remote won't work. Tried new
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Aug 22, 2011
joeguest2
  • 2080 Answers
SOURCE: Need the TV codes for Norcent Model LT-1931. My
If you do not see a TV code for NORCENT in the code list in your universal remote control user's manual, then try all the codes listed there for SAMSUNG which have been known to work for that brand.
Your remote control may also have a hardware fault such as a burnt out infrared transmitting LED or another failed component inside which would prevent it from working even with the right code. These are rarely cost effective to try to repair and you are probably better off just getting a new one.
Here is a link to replacement remote control for your TV currently available on Ebay for about $20 US plus shipping:
http://www.ebay.com/itm/Norcent-TV-LT1931-LT2231-Remote-/150452248022?pt=LH_DefaultDomain_0&hash=item2307a71dd6
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Otherwise you can upgrade to a decent quality universal remote. Norcent is not a widely distributed brand, so you would probably have to get one of the higher end universal remotes in order for it to function since the cheaper ones are not always programmed for the lesser known brands of TVs. A LOGITECH HARMONY remote is one of the best universal remotes in terms of quality and performance and can be programmed by computer to function with any brand of TV. These are somewhat expensive however, with some models priced at well over $100 US depending on the features included.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Sep 05, 2011
SD Tech
  • 14553 Answers
SOURCE: My TV remote doesn't work. I changed the batteries but that didn't solve the problem.
The remote can be tested and Radio Shack and most repair shops have a simple card for testing---point the remote at the card and press buttons and the strip on the card either lights up or not.
Depending on the problem most remotes are fixable.
Stay away from "Universals" as they are usually trouble.
If batteries and remote test good the set has a receiver for the infrared signal the remote sends-
95% of the time it is the remote and not the receiver or set.
A precise model number would tell me of common issues with your set including the remote.
Posted on Mar 14, 2012
  • 504 Answers
SOURCE: my remote doesn't work
possible solution
check remote ir led (infrared led) in IR reciver (any electronics repair shop) the finally u know yr remote was working or not if fail in this checknig then u buy new remote for same model
Posted on May 16, 2012
SOURCE: remote control doesn't work anymore
First thing is the check the batteries and the battery contacts
Posted on Oct 29, 2012
Remote & tv not working & no signal
Check the remote control for its infra-red emission. Check it with fresh batteries. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 15, 2014 | Viore Used Original LCD32VH56 Remote...
Viore rc5006v remote not working
Check the remote control for its infrared emission. Check its battery contacts in the battery compartment for any rust or dust accumulated. Clean them well and check again. If it does not help you, remote control need cleaning. You have to open it to do this. If you wish to get more details about how to clean and repair a remote control, check this link. Details are there. Pull up older posts.
Mar 16, 2013 | Viore Used Original RC5006V Remote Control
Remote control doesn't work anymore
Oct 28, 2012 | LG 47LG50 47 in. LCD HDTV
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
Westinghouse tv remote doesn't work
1) replace new batteries with the same tipe alkaline
2) see the polarities are wrong
3) clean the contacts batteries with c. cleaner
4) retight the spring contacts batteries with l plier for better contacts
5)open the r. control clean the keypads from dirty, corrosion, oxide and bad contacts.
6) reset the code
7) try again, if the problem persist go to the repair shop TV for fix it.
God bless you
Oct 15, 2012 | Westinghouse Used Original UW40TC1W Remote...
Vauxhall Astra's remote suddenly stopped working.
Start troubleshooting by redoing the "mechanic's" work, making sure that the correct and unblown fuses are in the correct places.
May 13, 2017 | Cars & Trucks
The remote control doesn't work anymore on my AIWA NSX-SZ50 compact disc stereo system.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Aug 14, 2011 | Audio Players & Recorders
My remote won't set to the tv I tried pressing the set button and it didn't work then I replaced the batteries to see if that would work but it didn't and now I don't know what to do please...
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
Jul 21, 2011 | Vizio VF552XVT 55 in. LCD HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
