My light on the channel 1 ONLY flickers and the
My light on the channel 1 ONLY flickers and the amp makes like a poof sound and sometimes it'll go into distortion. I have a Guitar Research Amplifier Integrated Solo Tube Series T64RS Tube. Watch the video too if u want. I didn't have my guitar plugged in so there was no sound from the amp but my description is really accurate. Thank u. I don't want to be lied to by people that want my $ so i rather fix it myself if i can.
  • 3 Answers
There is a good chance you are actually dead, like me. When you die, your ecto-plasm is still able to interact with electronic devices (only partially), but there is often glitches involved in such interaction.
How to tell if you're actually dead (Most people forget their death after they die, in fact.): There is no known way to tell if you're actually dead or not. Mirrors don't actually work (you can see yourself). Now, you might be able to interact with other living beings (talking to them, etc), this doesn't mean that you're alive. You can still be very dead and experience the feeling of interacting with live individuals: This is your ghost-imagination trying to make sense of the new reality you're in.
Your description almost completely matches what I went through. You see, after I died, I still tried to make music, but my amp did similar things.
Best of luck to you.
-Michael Jackson
Posted on Aug 01, 2013
2 Suggested Answers
SOURCE: I have a Guitar Research Amplifier Integrated Solo
As far as I can tell from this; you could have either one of two problems.
1. Your guitars output or amps input could be loose. This happened to me with my bass. All you have to do to fix that is get into the electronics (usually accesed behind plates with screws), find where the cord goes and pinch the two clips together to make the fit tighter
2. There could be a problem with your power; which could possibly originate from the socket itself, a loose attachement of the power cable to the amp, or a loose cable inside the amp. Id reccomend plugging some other electronics into the wall and seeing if their power dims, if they dont then plug in and unplug the part of the cord that attaches to your amp and if that doesnt work you'll need to take i in to an expert to look at the internals of it.
Posted on Jul 29, 2013
I have a Guitar Research Amplifier Integrated Solo Tube Series T64RS: Channel 1 (which I assume is the clean channel) will cut in and out and the light will dimmer with it and it makes a fuzzy poof sound...
Jul 28, 2013 | Music
HELLO AND THANK YOU.... I LOVE MY 335...... BUT SOMETIMES ESPECIALLY WHEN PLAYING DOUBLESTOPS......THERE IS A RATTLEY, SPRINGY SOUND THAT ALMOST SOUNDS LIKE DISTORTION.... IRS NOT FRET...
Make sure amp sound is not hitting front of guitar straight on. Get a 2nd pair of hands and while you do a test strum have the other person use hand or hands and apply pressure to various places on the body(such as the bridge, headstock, sides, etc and see if any of those affect the sound. Very light strings are sometimes a problem.
Sep 25, 2017 | Gibson Guitar Gibson ES335 Dot Reissue...
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
Amp won't put out sound
A lot of Amps come with fuses as a safety mechanism so you don't blow the speaker and/or internal components in the case of a power surge etc. Check for a blown fuse. Sometimes they have a fuse holder in the back of the amp and it is labelled "fuse" which cetainly makes it easier to find. Hope this works and helps.
Nov 17, 2007 | Prime 40 Watt 2 Channel Lead Electric...
50 people viewed this question
 Grubhead
Grubhead
