Remote wont work on soniq tv E55Z11A-AU
Remote wont work so i got another 1 the same QT141, and still wont work. I have to be within 50mm of the tv for it to work. Is it my sensor on my tv? How can i fix it?
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Posted on Aug 13, 2008
I heard that LG TVs have a problem with the TV not responding to the remote control (there is nothing wrong with the remote control). Hopefully your TV is still under the 2 year warranty. Go to LGService.com and report the problem. They told me that it's a common problem. They need to order the part and let me know when it comes in. (my TV is a LG 50PC1DRA)
The Akai TV might have LG guts inside.
Posted on Jan 06, 2009
techman007
  • 1112 Answers
SOURCE: Remote sensor on TV (LG 42PM1MA) seems to be broken.
Have the technician check for 5 volts on the remote IR Sensor if present the the Remote sensor has failed. Have him replace it to factory Spec's. No need to replace entire main board when the sensor is no more 5 dollars....
Posted on Sep 29, 2009
Testimonial: "Thanks a lot. Seems you've done this yourself :)"
SOURCE: LG LCD TV won't respond to remote controllers
sparrow00, your fix worked for me, and I think I know why. The 1/8" remote input jack on the back of the TV has electrical contacts inside that are probably there to sense the presence of a plug-in remote. When they detect the insertion of this plug they disable the front panel IR (infrared) receiver and the TV only responds to this plugged-in remote and the buttons on the TV itself. After some period of time these contacts get corroded and the circuit is no longer completed between them. The TV now thinks an external remote is plugged in, and it ignores its own front panel IR receiver.
When you plug a 1/8" plug into this remote socket on the back of the TV it wipes away the corrosion. When you remove the plug the internal contacts conduct properly again and the TV responds to its front panel IR receiver. For best results you should plug a 1/8" headphone plug into this remote jack and twist it a few times, then pull it out and repeat several times. Repeat every frew months or whenever the TV acts up.
Thanks for your solution!
Posted on Sep 01, 2010
gopakumarg43
  • 74459 Answers
SOURCE: T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Posted on Nov 28, 2011
What's the 3-digits code of Soniq tv using chunghop rm-309es universal TV remote
Sonber 0132
Sonic 0783
Soniko 0067 0586
Soniq 1497 1328
Sonitron 0238 0400 0369 0247
Sonix 1762
Sonneclair 0067 0586
https://iihelp.iinet.net.au/iiNet_TV_Remote_Universal_Codes_for_TV
Oct 31, 2017 | Universal Televison & Video
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
I have a Soniq E55Z11a TV and we did an auto search for channels. It is stuck on Installation Guide screen as no remote.
Does switching it off and back on at the wall help?
Page 13 of the manual shows the button functions (I'm sure you know). The alternative is to buy a dedicated remote from some seller like ebay.
SONIQ E55Z11A AU Instruction Manual Page 13
REPLACEMENT SONIQ REMOTE CONTROL QT141 E46Z10A E46Z11A E55Z11A E55Z11A AU...
Jul 26, 2016 | Televison & Video
How do I change the zone on my Soniq E32W13D-AU?
You should have got a red card with the AU and NZ customer support numbers on it. If you phone them, they will tell you how to unblock the player to make it region free.
On the Soniq QV191LC TV and DVD player, you follow these steps. It may work for your model but if it doesn't, try the support line.
1. Switch on
2. Switch to DVD mode (use Source button on remote)
3. Select DVD setup menu (press DVD button on remote)
4. Select Preferences page (use > key on remote)
5. Press '0' key 4 times on remote: the Region Code menu will appear
6. Use up and down on remote to select region (0 of course)
7. Press exit button.
You should now be region free.
Try these numbers:
AU 1300 765 663 / (61) 3 9543 5111
NZ (64) 9 2667512
If it's any help, you can download the manual here:
ftp://ftp.quatius.com.au/Manuals/E32W13D-AU.pdf
Jul 31, 2014 | Sony Playstation 3 (PS3) Console
Code for soniq tv
The codes are dependent on the remote so you'd have to also list the remote name and model, however, this is what Soniq wrote to another user with the same problem: Hi, we do not have the remote code for universal remote control. We recommend our customers to use a genuine SONIQ remote because some universal remotes are not compatible with SONIQ TVs and they may not have all the special buttons required. Please call our spare parts team on 1300 765 663 and they will be able to assist you further. Thanks.
Jun 14, 2014 | Computers & Internet
I have a 55inch led lcd soniq TV (E55Z11A) the TV remote light works but the TV sensor won't read the remote is there a way to restart the TV to make the remote work again?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts have details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
If the remote control is found OK, check and replace the infrared sensor inside the TV. Contact any service technician.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
May 04, 2014 | Televison & Video
Soniq qt141 remote control just stopped working new batteries in and still doesn't work,any suggestions?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
If remote control is found OK, set it up with set-up codes to your devce brand, and check. If it is universal remote control, it might have been rested when you changed the batteries. . If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Try this link too
Apr 17, 2014 | Hitachi CLU-4324UG Remote Control
Remote code for Soniq TV
Only code I could find is: Soniq 1497 1328
Nov 28, 2008 | Directed 434MHZ Remote Control
Televison & Video Logo
254 people viewed this question
Top Televison & Video Experts
Electro Med Services...
