Question about Toshiba TS-L532L DVD±RW Dual Layer Burner
Dvd not working
The dvd drive (TS_L532L) in my Toshiba Satellite laptop does not work. The operating system is XP home. It wll not burn dvd's or read regular CD's either. The programs I use (sonic, intervideo) all say please insert a disk in drive when there is already one in the tray. The disk brand is imation. Hope you can help. Thanks
  • onemoretime Aug 31, 2007
    Hi
    Thanks for quick reply. I downloaded what you said and when I click burn to disk, it says "please insert media to continue", but there is already a disk in the drive. I was thinking of purchasing another brand of dvds to see if that would help. Any ideas?
    Thanks
  • Toshiba Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Posted on Jan 07, 2012
Just as you said DVD was toast, have ordered a different one.
Posted on Sep 16, 2007
  • Toshiba Master
  • 12,061 Answers
Ok this type of thing is very common ... however often we chase our tails looking for a software fix when often it's the DVD/CD itself.. so to find out either way weather the device is FUNCTIONAL, download "CopytoDVD" here www.snapfiles.com/get/copy2dvd.html This has it's own ASPI recording layer... and if your DVD is FUNCTIONAL... then it WILL burn ya DVD... however if the DVD is, as I suspect, .. kaput! then it will NOT burn a DVD.. that's basically how we would "Test" Functionality. So if it works then ya all good.. else ya gonna haveta get a new DVD.
Posted on Aug 31, 2007
  • electronic & computer repair&  servicre
    It's as I said then.. if it don't work with this program.. ya need a NEW DVD .... :(
I have a Toshiba Satellite L750D and my TSST corp CDDVDW TS-L633F ATA device, {CD/DVD writer} will not read nor recognize and CDs...as soon as I press D: , the door opens and I get prompted to load th
Go to "Control Panel, then " then "System and Security" and then "Device Manager". Check under "DVD/CD ROM Drives" to see if you Optical Drive is indeed listed. If it is not there, it needs to be reinstalled. Go to http://www.mytoshiba.com.au/support/computers/satellite/l750/psk2ya-04k010/download?os=25 and download the "Chipset" driver for the appropriate Operating System and install it and then reboot your system and see if the drive has been found.
If the Optical Drive is present, you can delete it and then download and install the Chipset driver to replace it with a correct driver.
I have seen this happen multiple times with Toshiba laptops. Good luck.
Feb 08, 2015 | Toshiba Computers & Internet
Where is the wireless on TOSHIBA SATELLITE 2805-S301
Hi just go this link below:
http://www.user-guides.co.uk/cddownload/Toshiba-Satellite-2805-S301-Windows-7-Driver-CD-Recovery-Restore-Disk-326243.html
Jun 19, 2011 | Toshiba Satellite 2805-S301 Notebook
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
Why Won't My Toshiba Satellite Laptop (A200 -AH3) Not Burn Discs?
Look for any software on the machine that uses the the burner. Start by updating it (many of these programs use what are called burning engines to process the request to write to a cd, and if theyre damaged, then the writing process will appear to occur, but wont do anything). If you use programs that download and manage music (such as Limewire, Bearshare, or Napster), uninstall them.
As a last ditch effort, you can try the istructions in this Microsoft article:
http://support.microsoft.com/kb/314060
Be warned, you will have to reinstall the software needed to burn your CDs if you do this. It has fixed 99% of CD burning issues out there. Good luck
Mar 05, 2009 | Toshiba Satellite A135-S2386 Notebook
My asus drw-2014l1t dvd ram drive burning error
Take a look at this registry key - you might have a different GUI id after Volume
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives\Volume{1365b506-f359-11dc-ac07-806d6172696f}
There should be a REG_DWORD called DRIVE TYPE
The values should be 1 for a CD-R and 2 for CD-RW
To verify - Go to My Computer and Right click the CD/DVD drive and then Properties.
You should now have a RECORDING tab and be able to burn CDs and DVDs
You need to re-boot for 3rd party software such as Roxia etc to now see the drive
Aug 16, 2008 | Toshiba TS-L532L DVD±RW Dual Layer...
Cannot write to CD/DVD drive; but can read
aslong as your 100% that it is a cd/dvd burner , can you please tell me the operating system that you are using and what programs you are using to burn , and are you trying to burn a cd , or dvd , or both ...
Nov 16, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba 1800 satellite laptop s253
you need to buy windows xp for a software shop. it will come on a cd/dvd. all you have to do is pop the cd in the computer and follow the on screen instructions.
Sep 22, 2007 | Toshiba ZA2055P08 - Satellite 1800 24X...
Toshiba TS-L532L DVD±RW Dual Layer Burner Logo
208 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
