Question about Garden
Ford yt16h garden tractormauual
How do I mount the tensioner bracket on the deck of my Ford YT16H?
2 Suggested Answers
SOURCE: Need a downloadable parts diagram for a Ford YT16H lawn tractor.
go to New Holland's web site they have all the info you need,heres the web site just type in "YT16H" in the parts search box and all the years will show up. Its not downloadable but you can certainly print out what you need.
https://webparts.pvassociates.net/cnh/webparts/main.php
Posted on Jul 25, 2009
How do I find a deck belt for my yt16H and idle pulley
Look parts diagram in your owner's manual
Sep 27, 2014 | Garden
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
Replace belts on 917-271821
The deck has an idler pulley that keeps tension on the belt. The idler pulley is mounted on a pivoting bracket, that has a spring which provides the tension. You have to move the bracket so as to take the tension off the belt, thereby allowing you to slip the belt off the other drive pulleys
Aug 15, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna YTH2348 hydrostatic transmission slipping
Check your tensioning bracket, when parked and engine off, lower the deck, look underneath from the left hand brake pedal side and work the brake pedal by hand take notice of the bracket with two pulleys mounted on it that move with the brake pedal being pressed and depressed, if you have vertical? up and down movement opposed to horizontal fwd and back movement your bracket mount and or bushing could be worn out.. Mine was, and after replacement it was like the day I bought it new.
Hope you his helps..
Jul 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do I replace the main drive belt on a Craftsman LT1000 lawn tractor?I need a schematic
No you don't, it's easy. Pull all the cotter pins out of the deck mounting brackets until the deck is laying on the ground and slide the deck out to the side. Make sure the parking brake is engaged so you have enough slack for the belt and start in back and work your way forward. You should see a little picture there somewhere on the mower of how to thread the belts through the tension pulleys. Then, put the deck back on.
Apr 24, 2010 | Craftsman Garden
Need a diagram of the adjustment or tension bolts for installation of alternator on 1995 Ford Aerostar-4L, Front 2 wheel Drive
This is from the workshop manual, direct quote.
Generator, Aerostar
Removal
1. Disconnect battery ground cable (14301).
2. Remove snow/ice shield.
3. Remove engine air cleaner intake tube (9A624).
4. Disconnect generator wiring at the voltage regulator (VR) (10316).
5. Remove attaching nut and wire from generator (GEN) (10346) output terminal.
6. Remove wiring connector bracket.
7. Loosen the drive belt tensioner (6B209) and remove the drive belt (8620).
8. Remove generator brace (10B315) and bolt attaching generator to drive belt tensioner bracket.
9. Remove generator from the generator mounting bracket (10153).
Installation
1. Position generator on the generator mounting bracket.
2. Install the attaching bolts and tighten to 40-54 Nm (30-40 lb-ft).
3. Install the drive belt over generator pulley (10344).
4. Adjust the drive belt tensioner as outlined in Section 03-05.
5. Install wiring terminal and attaching nut on generator output terminal.
6. Install wiring connector bracket.
7. Install engine air cleaner intake tube.
8. Install snow/ice shield.
Nov 05, 2009 | 1995 Ford Aerostar
How does the timing tensioner work on a 1996 ford escort
When you loosen bolt in center of pulley, it's will slide to left, to reduce tension, or to right, to add more tension. It's mounted on a bracket that has a horizontal slot about 2"-3" long for it to slide from side to side.
Oct 25, 2009 | 1995 Ford Escort
Jul 14, 2009 | Ford Garden
I have a ford lawn tractor with a hydroststic trans what oil does it take and what oil does the differential take
Ok...My YT16H ford takes SAE 20W and the differential takes SAE EP 90W. I hope this will help you.
Jul 03, 2009 | Ford Garden
Where can i find the main bracket for my alternator on a '88 ford
look for same model of your vehicle at local junkyard or go to factory to get newone
Mar 15, 2009 | 1988 Ford Econoline
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
