Question about Jenn-Air Ovens
I have a Jenn Air oven m/n JJW9527AAW with no display.
I highly suspect that the display (CN:7601P568-60) is bad. It has power +12.3vdc going to it. Anything else to check.
  • 184 Answers
SOURCE: Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Posted on Apr 10, 2008
SOURCE: F2 code on Jenn air double oven
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Posted on Feb 06, 2009
SOURCE: Jenn-Air oven display blank. Only works when oven has heated up.
I had the same problem and just fixed it myself today. Not sure if your timer board is the same but I replaced capacitor C3 35volt 68uf. I also have the dark spot on the clock glass in the corner but it still works. I purchased the cap from digikey.com P10292-ND. I also replaced the cap next to it 35volt 470uf P10301-ND not sure if that was necessary but it smelled a little burnt. The display is normal brighness again - total cost 1/2 hour of my time and $4 parts and shipping. Digi-Key is great I ordered the parts on Thursday 7/23 and got it today 7/25.
Posted on Jul 25, 2009
  • 19 Answers
SOURCE: Jenn-air expressions wall oven clock went dim, now out completely
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
SOURCE: Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Posted on Mar 19, 2010
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
The digital control display is extremely dim
your model should be a jjw9527AAW.... usually when that clock assembly goes dim u must replace that clock ... for your model it is a part number #71003424.. that clock on sears.com is for sale at $186.06.. call around or shop around for a bettter price remeber shipping charges through sears though and prob take longer to get ahh nevermind ur call...ohh yea kill the power before servicing or call for service... hope this helps take care
Jan 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Oct 08, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
My jenn air model ww2780w double oven has nothing lit up in the digital panel, and i cant use the darn thing. Help!!!
BrianGem posted a great solution back in May of 'o8, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board appearently has a weak spot in the design, most likely heat related, (probabily low priced components from offshore sources)
Fix: Replace heat dammaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm luckey enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recomend changing sizes without design review for fear of overloading another componant, however several other posts have indicated a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capicator is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unpluged. Capicator is likely discolored or leaking, Desoulder it and replace with new, match polarity marks and dont use any more soulder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS. and good luck.
May 12, 2009 | Jenn-Air Electric Double Oven
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn air 2001 double oven , light display is out...
it would be nice to figures this out but i have not. the light unit or the power supply unit is bad but i don know which. both units cost about $150 each. so you want to be sure when yoou order your part which is bad
Nov 07, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
73 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
