Question about Kenmore 15864/15862 Top Load Washer
My whirlpool washer model # LLR9245Bq1 only goes in spin cycle, no water comes out, what is the problem?
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
GodBlessU
  • 3513 Answers
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Posted on Aug 11, 2009
  • 4 Answers
SOURCE: Will not drain or fill
just hit it with a hammer. thats what worked for my flat screen tv.
Posted on Sep 11, 2009
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Oct 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
