I need instructions for the Apco PJ968 projector please
Why does the projector display blurred images
It sounds like your Projector needs focusing, Please see the image I've added for help, If it isn't that then please let me know and I'll see if I can help further, Use of any instructions I offer is at your own risk.
Jul 30, 2014 | Dell 4210X DLP Projector
Troubleshooting benq cp220
You don't need any software to make your projector work with your PC. Here is the instruction for the Projector. (http://bit.ly/1byZlZT)
Instructions:
1: Plug your projector to your PC.
2: On your projector Choose your input device. (In that case your PC)
3: If you find any connection from you PC you will see same display as your PC. ( You will see a Duplicate of your Screen, you can configure it to be a separate screen).
4: you are done. :D
If you need Further help please do contact me or Replay.
Thanks
Feb 08, 2014 | BenQ Computers & Internet
Uniden bcd 396t apco 25 scanner trouble shooting
If you are listening on a particular frequency, you will hear all the units using that frequency
Oct 15, 2012 | Uniden Bearcat Bcd-396t Apco P-25 Digital...
How do i program a apco 25 freq into the scanner
Just program a p-25 apco into a regular channel of your scanner... in your conventional scan mode...Just go to a certin channel of your scanner and program it in and it will automatically come in the APCO -P25...I have one of these scanners....ITs a wicked scanner...a good one...
May 02, 2011 | Uniden BC796D Base Scanner
Is this APCO-25 capable,the APCO-25 is the digital
No. The PRO-97 can receive both standard and trunked analog signals, but it is not digital capable. Also, there are no add-on boards or circuit modifications that can enable digital operation.
Bill B.
Listening in since the 60's
Feb 17, 2011 | Radio Shack Pro-97 Handheld Scanner
I was given an old uniden bearcat 16 channel 10 band scanning radio bc144xl and i would like to hear all the fire,police and emergancies in my area but i have never had a scanner befor and dont know the...
Programming the BC248CLT is fairly simple, and detailed instructions can be found in the factory manual that you can download and print here:
http://www.uniden.com/pdf/BC248CLTom.pdf
What you can program and what you can hear will depend on your location. Many communities now use trunking systems and digital (APCO-25) systems, and your scanner is not compatible with either. For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Sep 12, 2010 | Uniden BC248CLT Base Scanner
Is the pro 2055 digital ?
The PRO-2055 is a versatile conventional/trunking scanner, but it does not have the capability to monitor APCO-25 digital transmissions. For an operating manual that is "Easier To Read" than the factory operating instructions, follow this link:
http://marksscanners.com/97/97.shtml#receive_modes
Bill B
Sep 09, 2010 | Radio Shack Pro-2055 Base Scanner
Can the pro-94 receive digital signals
Unfortunately, no. The PRO-94 can monitor conventional or trunked analog systems, but it cannot process digital signals. To do that you'll need a scanner that specifies DIGITAL, APCO, APCO-25, or P25.
Need the manual for your PRO-94? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
BillB
Jan 19, 2010 | Radio Shack Pro-94 Scanner
Some frequncies come in with tone not voice ,lower channels come in but higher one started this morning
find out if what you are listening to has gone to digital... in particular apco 25. if so you'll need at the minimum a scanner that will work on apco 25. look at the specs on a pro-96 to see what you will need.
Jan 11, 2010 | Radio Shack Pro-2051 Base Scanner
63 people viewed this question
k24674
jasbo
jasbo
