Question about Garden
How to wire solenoid on poulan pro lawn tractor
Need to replace solenoid on Poulan HD21H42. Not sure on wiring
SOURCE: why does the deck belt keep breaking on Poulan
its possible the belt may not be on the correct pullies. check the diagram and make sure it is routed correctly.the guy i bought my used mower from had same problem. i corrected belt route and have not broke a belt in the two years i've had it
Posted on Apr 13, 2009
SOURCE: Need lawn mower manual
need manual for pb195h42lt
Posted on Apr 24, 2009
  • 246 Answers
SOURCE: I need an electrical diagram of the snapper lawn tractor
Hello:
Try this Site Addy;
>>You can View a Breakdown of the Mower at this Site Addy; http://www.snapper.com/manuals/ . Enter your Model Numbers in the Box Provided and Click Find Manuals. Select Illustrated Parts List from the Manual List Provided. Now Download the Manual for Online Viewing.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 26, 2009
  • 95 Answers
SOURCE: Loss on drive on Poulan Lawn Tractor
Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
Posted on Jul 30, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
I have a pb2042yt clicks when try to start chkd batt , solenoid and starter all good .( chkd by pros ) . What now ?
I would remove the connector to the ignition switch and check for corsion, clean and replace. If that did not fix it, I would check signal wire going from the switch to the solenoid. The click you hear, is it the fuel shut off solenoid? Need to know what you have checked on the mower itself and what exactly you have power and ground to and what you dont. Your solenoid, does it have 2 wires or 1? ( I am talking about the small wires, not the battery wires) If it has 2, find the one going to the safty switches, should be white, if you ground that terminal to the frame or battery and test then, ( THIS IS FOR TEST ONLY, DO NOT OPERATE LIKE THIS, VERY UNSAFE) If it starts like that then you know the problem is in the interlock system, if it doesnt then you will have to look at the switch , solenoid and starter all over again..
Apr 11, 2014 | Poulan Pro PB2042YT 42-Inch 20 HP Briggs...
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
My lawn mower will not move
This is a micro switch, or relay issue, make sure the wires are fully pushed home in the switch under the seat, if ok replace the switch, if no better replace the relay behind the dash board.
Jun 26, 2013 | Poulan Garden
Need to locate a diode for a Poulan Pro riding mower
it is on the engine side of the two wire plug going to the engine it will only be a slight bubble in the wires
Apr 03, 2012 | Poulan Pro Garden Tractor 2005 and Older...
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
