Question about Acer Aspire X1200-B1601A PC Desktop
Pci adapter slot
I want to give my PC the possibility of connecting to Wi-Fi networks.
spare_head_2
  • 47 Answers
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Posted on Jan 04, 2008
  • 37 Answers
SOURCE: wireless network adapter
pci slots are all similar except for pci-x16 and x1 of course but it shold be a simple process of slotting the card into a free pci slot and then letting the os recognize it.
hope this helps
Posted on Mar 31, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
SOURCE: install ethernet wireless in pci slot
Yes you should have a few white color slots in there and the card will just slide into the slot. There is nothting on the inside to connect to other than teh slot.
Posted on Jan 02, 2009
SOURCE: wi fi connection
Try to check on the device manager if the wireless adapter and the ethernet adapters were installed properly. If it appears with a questionmark, uninstall it and try reinstalling it without the ethernet cable connected.
If you are using Vista system, after installing the adapters, go to the network connections and just click on tcp/ip then click on properties. Exit from the window by clicking ok until all windows will be closed for the network connections. Reboot your pc and try if you can obtain a connection.
Posted on Mar 11, 2009
What parts are needed to set up wifi?
That machine does not appear to have any PCI slots, or built-in WI-Fi. You may be able to get a USB 2 Wi-Fi adapter. Just make sure the one you get works with your Operating System. Also, you will have to have a Wi-Fi router to connect to your Internet Service Provider.
Jun 25, 2014 | eMachines EL1852G-52W
Is it possible to get a wireless connection to the vaio PCV-RX221
Vaio PCV-RX221 does not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Sony VAIO PCV-RZ221 PC Desktop
My pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY INTERNET SEVICE MODEM IS WI-FI ENABAL,BUT MY PC IS NOT WI-FI. HOW ITS WI-FI CAPABLE NOW
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Apr 11, 2011 | Computers & Internet
Greetings, I am a technician. However, I ran into a confusing issue with my wi-fi. My Encore enlwi-g v2 PCI wireless adapter worked fine on my Windows 7 64-bit system until I bought a new Smilodon case...
Mike, your problem is so clear and crisp... Thank you for the excellent documentation...
Here is the solution...
The wireless PCI card should be detected by any PCI slots, doesnt matter whatever may be the chipset made off...
The Light in the adapter is "OFF", says there is no power supply to the adapter and that is the reason the Wireless card is not detected...
unplug the adapter from the board and clean the PCI slot on board with a soft brush(the Pins in the PCI slot may get in contact with each other if u use any hard materials to clean)...
On the PCI wireless card clean the metallic contact surface (the place where the pci slot comes in contact with) using an ERASER and clean the dusts left by the eraser properly...
Now connect it back and check if the light is getting LIT up on the card...
Then you can also check under device manager either in Network adapters or under other devices...
Sincerely, Manny...
Dec 09, 2010 | Encore (ENLWI-G) (ENLWIG) 802.11g/b...
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
I dont know how to turn my wi-fi on on this labtop
look around ur laptop, there should be a button key or a switch 2 turn it on. if look on the bottom right on ur taskbar, there might be an icon for ur connections e.g. bluetooth, wlan, wi-fi etc. see if u can switch it on from there. if u still can't do it take ur laptop 2 a pc world center and they might be able to help u. i hope dis helped =)
Aug 26, 2009 | Everex StepNote NC1502 Notebook
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
Broadcom 4321AG 802.11a/b/g/draft-n Wi-Fi-Adapter datasheet
that depends on the network traffic to and from your computer..but it will never be 0 once connected..
Jan 14, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Acer Aspire X1200-B1601A  PC Desktop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
