Question about Sony KV-32V35 TV
Sony KV- 32V35 Front Jacks
Hello. My front audio/video jacks are loose and I do not know how to access it for the purpose of repairing it. They are in a state such that when a video jack is input there is no connection, however if i wiggle it it will show me a picture. This leads me to believe it is loose. To reiterate, how do I access the audio/video jack in order to fix this? Thankyou
  • zeljko Sep 01, 2007
    Thanks for the advice mike. Awesome response time too. God bless
  • 398 Answers
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Posted on Aug 31, 2007
SOURCE:
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
I just ;purchased this Sony model used from a Salvation Army store...it was working beautifully in the store. It came with no manual or remote. We have NBA League Pass and that comes through a DVR box...
look where it said input 1 , input 1 is the same input u where using before and put yelloy with yellow white with white and red with red , yellow is the video , white and red are the audio
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
What is the purpose of the front audio/video jacks on an Emerson Vcr Ev818. My cord is too short to reach the jacks on the back of the Sharp tv. Can I record on the vcr using those front jacks on both...
The front jacks on all VCR's are for video cameras etc. Generally VCR's have one or two scart sockets on the back for connection to TV's. If only one, or you haven't enough scarts on the back of your TV, I suggest you get a switching box like the one in the picture below (found on Amazon). It will solve any connection problems and recording issues.
Sep 29, 2010 | Emerson Televison & Video
Connect PS3 to Sony Trinitron. We connected with the PS3 provided AV Cable to the front Audio/Video jacks but cannot get a picture on the TV screen. Not sure what we are doing wrong.
easy breezy fix, you have to force the ps3 to acknowledge that tv is not hdmi, it is just hd. press and hold power button for 5 seconds on ps3 until you hear 2nd beep and let go. settings will come up for ps3, switch to hd. done
May 22, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
I have just purchased a new compuer with Windows 7 and ASUS P5KPL-AM/PS motherboard. There are two fron jacks for mike and spkr but what is the purpose of these? as they dont seem to work. Only the rear...
it means that the person responsible for assembling your pc have not connected those jacks to the motherboard and therefore only the rear jacks work.
the purpose of this is to give you easier access to microphone and speaker as they are located in the front of the pc. this is used for people who don't have a permanent set of speakers and may connect headphones occasionally.
Jan 26, 2010 | Office Equipment & Supplies
Trouble connecting Nintendo Wii-- No video coming up on screen
What jacks are you plugged into? There are composite video jacks (yellow) as well as component video (red/blue/green). Three differnent video inputs on that set. Video 2 is composite on the front panel.
Jan 10, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No video on VIDEO 2...cold solder connections on video and audio inputs...resolder, but solder pad for video has no connection ...looking for a pictorial view of the PC board to insure there is a...
I just fixed this on my TV. With the small front input board removed from the tv, solderside up and the rca jacks pointing away from you begin.Looking at the board in this position locate RCA video jack. Directly in a row are 2 comparitively large solder pads. The pad furthest from the RCA jack and closest to you has a thin trace that runs from the noted pad to a solder pad on a small surface mount component marked 750. That small trace is not making contact on the solderpad that is soldered to the RCA jack. To fix it take a small metal pic or tiny flat screwdriver and scrape away some of the PC board coating right on the trace where it meets the solder pad, and place a small solder bridge on it. Thats it put it back together and watch TV. Thanks to all the members here who post solutions. Frank
Dec 01, 2008 | Sony KV-32S20 32" TV
Loose jacks
me too need, give me plz
May 17, 2008 | Computers & Internet
Televison & Video Logo
150 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
