Question about Epson STYLUS PHOTO T60 INKJET PRINTER
How i can clear counter? - Epson STYLUS PHOTO T60 INKJET PRINTER
  • Epson Master
  • 27,725 Answers
Which counter ? Is it the print cue ?
((make sure you have the printer turned off)) otherwise it might print another page
if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a
display print queue tab you can see all prints right click on the ones you don't need select cancel
http://resetcounter.com/tag/epson/
Posted on Jul 30, 2013
Konica minolta 282 c2557 code appears after developer was replaced and counters were cleared and f8 was run
After clearing the counters did you touch "END" and then power off the machine. Check your counters again if they did not clear get new developer and drum and start over
Sep 21, 2016 | Konica Minolta Office Equipment & Supplies
From meter counter how can I remove code m2 of minolta 6001
stop 0 stop 1 , counter, clear the drum and developer. ARE YOU REPLACING THE DRUM AND DEVELOPER,
The copier works on the counter clear the counter and not replace the parts that counter is monitoring and you will have codes and image problems the counters tell the copier parts are new and to adj assigned voltages as required.
Nov 20, 2015 | Minolta Office Equipment & Supplies
Bizhub c350
Before replacing the IU select Utility - Meter count - Check details- Stop 00 Stop 01,enter 00000000 END,select Tech.Rep.Mode - Counter - Special parts counter-PC life.Press the Clear key to clear the counter value.Select IC life and clear the counter value.Turn OFF the copier and remove IU unit.After installing the new IU unit select Tehc.Rep.Mode -Function-F8 and press START.After 2 minutes the developer is initialized to make a copies. fcf3fced-96eb-4483-840f-8de548aa8045.jpg 378b39ea-2f19-4cf6-887c-617430da4931.jpg
Jul 14, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Maintenancecall 2
First it indicates that the drum needs to be replace along with developer. has that been done? Then who did it for got to clear the counter. Go to service mode Utility then stop 00 stop 01 . Then to # 9 Clear counter then to supplies life counter clear yes exit out
Apr 05, 2014 | Minolta bizhub 180 Black and White Copier
Dialta di181 clear M4 error code
M-4 replace the drum it has reach the max of 80,000 copies. replace the drum then clear the counter. just clearing the counter will not be good the machine knows when the counter is clear it has a new drum and will adjust High voltages accordingly if the old drum is in there then you get code and image problems
try web site below for part start with drum being replace recommend the cleaning blade also be replaced. Don't for get to clear the counters first install the drum and run F5
Feb 17, 2012 | Minolta DiALTA Di181 Printer
When we are trying to scan documents we get a message that says, "Please replace your PC drum"
Simply replace the pc drum.If you do not want to then do this,Press utility/counter buttonpress detailsnow press stop,0,0 stop,0,1 its the code to get into service modewhen you are in service mode press counter,in counter menu press parts life counter, select it and press "c" to clear its counter.clear all the counters like maintenance counter, life counter etc.after clearing restart the machine and this message will be gone.If you cannot do this then don't worry this message will not affect the print quality or even the machine.
Mar 29, 2011 | Konica Minolta Bizhub 222 Black and White...
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Pc drum
Replacement of the Photo Conductor Unit
1. Select Tech. Rep. Mode → [Counter] → [Special Parts Counter] → [PC Life].
2. Press the Clear key to clear the counter value.
3. Turn OFF the main power switch.
NOTE
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
4. Open the Right Door.
5. Remove the IU. Carefully pull on the two green handles
6. Remove four screws (silver) on the sides and disassemble the Photo Conductor from the Developing Unit.
7. Replace the Photo Conductor Unit
8. To reinstall, reverse the order of
removal.
NOTE
• Replace the Toner Filter (Developing
Unit) with a new one at the same
time.
Jun 06, 2008 | Office Equipment & Supplies
Epson STYLUS PHOTO T60 INKJET PRINTER Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
