Question about Swisher 22"Deluxe Wheeled Trimer/Edger
How to change belt on swisher wheel trimmer / mower
  • 42 Answers
SOURCE: Trimmer line for Swisher ATV Postmaster Trimmer.
I have found that you can use any kind of trimmer line that you want, but the size has to be .155" trimmer line. Also, below is a website with the manual for your postmaster. I was also wondering how you liked your postmaster? I am really thinking of getting one. I run cattle on about 8-10 miles of electric fencline and am always having to take the handheld trimmer to the fenclines to clean them up so the electric fences don't get to bogged down. Let me know. thanks. below is the website.
http://www.swisherinc.com/manuals/PDF/ST/PST04.pdf
Posted on Mar 15, 2009
cq92
  • 184 Answers
SOURCE: i need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Posted on Aug 30, 2009
mowerman1857
  • 389 Answers
SOURCE: i need a belt diagram for a 60 inch Swisher lawn
There is a good repair manual here:
http://www.manualnguide.com/dl/3425/
Posted on Sep 22, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
MNfisherman
  • 11896 Answers
SOURCE: how can I put more tension on the belt of my 44 inch swisher trail mower
I would try replacing the spring
Posted on Jun 10, 2012
What size is deck belt for swisher trail behind 44'' modelt11544
Swisher 4220 74-Inch Belt - Fits select Swisher 44-in, 42-in and 22-in Mowers
Jun 22, 2015 | Swisher Garden
Adjust belt tension and brake linkage on Swisher 44 in 11.5 HP mower
is the belt tension adjustment on the lever that engages the blades?
Mar 29, 2013 | Swisher Garden
Mower is the Swisher ZT 2660 runs great. Blades slow then stop during cutting, I changed belts (drive & deck). Last year you advised it maybe the electric clutch. Question is that a do it yourself...
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
May 01, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
How do i replace the hydro belt on the swisher zt2660? my belt broke after 35 hours. when i put the new belt back on it was loose and i can't figure out what needs to be tightened. i also find it very...
A mower with 35 hours should still be under warranty, and a belt shouldn't break at 35 hours unless you ran over something that got caught in the belt. I would take this unit back to the dealer - it is their responsibility to repair or replace your mower.
Here is my advice on how to change a main hydro belt. To get enough room to work, jack up the back of the mower (put blocks in front of the front wheels first) then make sure the back end stays up with jackstands under the chassis, or use bricks or blocks under the rear wheels. No matter what, you'll be laying on your back working in a cramped space. So don't tackle it if it's the dealer's responsibility.
If you've replaced the belt but can't get it tight, check that the idler arm spring is hooked up properly so the idler pulley presses in on the belt to tension it.
Jul 14, 2010 | Swisher Zero-Max 60-Inch 26HP Zero Turn...
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
I need a belt diagram for swisher t60 trail mower
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Swisher 22"Deluxe Wheeled Trimer/Edger Logo
83 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
