Question about Denon DN-2600F CD Player
Dual cd player
Disc # 1 takes almost 3 mins to read cd's
My problem is tha trsitor tr601 what number is
Posted on Apr 23, 2009
  • darefon Apr 23, 2009
    my denon 2600f cd will not on
One side of my denon 2600f cd player will not read a disk. What can I do
Posted on Feb 07, 2008
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
My cdj 800 is having a problem with cd reading.its not reading cds as it was new..just 1 year nw for my player.if put cd inside it cums out afetr 2,3times if i insert cd inside then it getging read......
Sometimes so CD does not play in certain CDJ, i have 2 or 3 disc which
does not play or eject when i try to play in CDJ 100s but when i play them
in another player they go well.
Pls try to have some other brand disc or you may clean compartment of the CDJ their may be dirt inside CDJ. I hope this will help.
thx,
djajay
Jan 29, 2010 | Pioneer CDJ-800 Turntable
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Hard drive not Reading CD-R Discs
First off. Your hard drive cannot read CD's. Your CD-ROM is not reading CD's. Well a few things can be wrong there. 1. The CD-ROM is dead 2. The drivers for the CD-ROM needs updating 3. The CD that you are trying to read is curropt or damaged.
Start checking to eliminate and let me know.
Aug 13, 2009 | Acer America Co - Aspire Desktop 4GB 640GB...
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Audio Players & Recorders
Converting a sony mini disc into a mp3/audio cd
i understand (i've gone through 3 sony md recordable players & now i have about 15 - 20 md with good mixes from clubs/carribean islands beach partys) the only thing i can suggest is invest in another mini disc that is capable of playing the 74 min disc (and speed that was recorded) here are two sites to check out 1--http://shopping.yahoo.com/s:Portable%20MiniDisc%20Players and 2-- http://www.google.com/products?hl=en&q=mini+disc+player&um=1&ie=UTF-8&ei=OhkbSozEApC6tAOr9NCSDw&sa=X&oi=product_result_group&resnum=4&ct=title
Nov 25, 2007 | Sony Net MD Walkman MZ-N910 Portable...
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
344 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
