Question about Yamaha RX-V2090 Receiver
No Sound Just picked up a yamaha rx-v2090 at an estate sale...bought new 16gauge speaker wire but not sure how they attach to the receiver. Do I need to purchase another part; an adapter of somesort to insert the wire into first, or do i just simple insert the wire into the speaker connections on the receiver (there are some many connections/which ones do I use). tried searching for a receiver manual but no luck yet. Seems simple but maybe I am connecting something wrong.
  • Anonymous Mar 18, 2014
    I am connecting my Yamaha RX-V2090 receiver to bose acoustimass 10 version IV I must doing something wrong because I can not make it sound. Please give direction how what to do.
    No sound what is the right way to make plugging .
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Posted on Dec 04, 2007
SOURCE:
Main speakers do not work on yamaha 2092
is the speaker select button pushed in?
Jan 08, 2014 | Yamaha RX-V2090 Receiver
Hellow, I own a rx-v2090 , everythings works, the problem is if i crank the volume to 11 to 12 O' clock position, it looses the base and half a minute later it shut itself. please can you explain to me...
Sounds like from what you describe is that your speakers ohms might be to low for the Receiver and making it over heat.Take a look at your speakers ohms rating and then look at what your Receiver is rated for most receivers can handle down to about 6 ohms nothing lower.There are some out there that can handle lower but from what I can see about yours it handles about 8 ohms.
Jun 16, 2011 | Yamaha RX-V2090 Receiver
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Sound not coming through speakers correctly
Check that the speaker setting on the receiver is set to large not small. (if you have 6inch or larger woofers)
If you have only small speakers you will need a subwoofer.
Feb 22, 2009 | Yamaha RX-V363 Receiver
Main speakers A and B not working...
Please preform Test Tone check and adjust front speaker level that seems very low.
Feb 20, 2009 | Yamaha RX-V2090 Receiver
Is there any DTS decorder player that suit with Yamaha RX-V 2090? Thank you.
Try the Technics SH-AC500D Digital Surround Processor. Its outputs should match the inputs on the RX-V2090. I own both units, though I am using a DDP-1 with the Yamaha receiver. I use two separate amps with the Technics to achieve surround sound using my good vintage stereo system (two of them actually - one for front and ane for rear). The Technics is a nice piece of kit.
Aug 13, 2008 | Yamaha RX-V2090 Receiver
How I connect DVD Player thru Yamaha RX V2090
please check your input source in tv and confirm right selection-check interconnect cables.
Jul 21, 2008 | Yamaha RX-V2090 Receiver
How to run outdoor speakers from my in house receiver
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Jun 03, 2008 | Yamaha RX-V2090 Receiver
Two possibilities for the no sound on the main speakers:
1) May be caused by the lack of the pre out main in jumper on the back of you reciever.
2) Check to make sure the -10db selector is not stuck between positions.
Dec 16, 2007 | Yamaha RX-V2090 Receiver
RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Jun 23, 2007 | Yamaha RX-V2090 Receiver
Yamaha RX-V2090 Receiver Logo
225 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
