Admiral washer ATW4475VQO
My washer wont completely fill it is only accepting hot water on all temp. cycles. we replaced both hot and cold valves we have good pressure.
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
mastatech
  • 478 Answers
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Posted on Jan 10, 2010
SOURCE: I have a Miele W1918 washer which has worked
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Posted on Nov 28, 2010
FitzOriginal
  • 842 Answers
SOURCE: Admiral Capacity Plus Washer -
This is almost certainly the result of the fill sensor failing. intermittantly
Essentially, the sensor is a bellows device. A pipe is connected to the device and as water reaches the end of the pipe and advances up it, the air pressure in the pipe increases, inflating the bellows. As the bellows inflate, they press on and trip a microswitch inside the sensor and cut the power to the water inlet valve, stopping the water flowing into the machine when it reaches the correct, measured level according to the pressure in the pipe.
Take the top off the machine, if you look down the side you will see a (typically clear plastic) tube about the thickness of a pencil, connected to a circular device about the circumference of a coffee cup and about an inch to two inches thick.
This is the sensor. Problems with it may be:
It has come unclipped from where it should be mounted. The device is VERY sensitive and if it has slipped out of place, over or underfilling is common. (Reposition the sensor, hopefully you can see where it came from!)
The pipe that is connected to it has come off, so the air pressure that the sensor measures is not increasing as the machine fills (push the pile back on and all is well)
The machine has been subject to some trauma (Such as a very uneven load that has made it shake violently. The starting level of the water that is in the bottom of the pipe is now wrong and the pressure sensor is being affected. (Remove the pipe from the sensor, blow down the pile to get any water that should not be there out and then replace the pipe).
Posted on Jul 07, 2011
elisa_ashley
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
Posted on Sep 21, 2012
After 2 yrs. the cold/cold selection doesn't work at all but the other selections give me hot h2o only. Also, rinse cycles just stopped working!
Your water inlet valve has 2 electric coils on it. One for hot --one for cold. The cold is probably bad. Most newer machines use COLD rinse only so if no cold fill it just stops in the rinse cycle. Replace the inlet valve which is the part on the machine back the hoses hook to.
Mar 23, 2015 | Admiral AW22 Top Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Admiral washing machine water not hot enough during all cycles.
newer washers have a temp sensor and the washer is programed for around a 100 to 110 degrees F, depending on manufacturer, so if your washer is new it is doing what it is supposed to do, sorry.
Jan 03, 2012 | Washing Machines
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
When washer machine is filing up with water is it normal for all hot then all cold water to come on instead of even mixing of the two? I have found that the constant back and forth with hot and cold...
Automatic temperature controls for different appliance manufacturers work in varying ways, but respond according to the control board response to the resistance of the thermistor. It is possible that your thermistor is bad; but what you describe is really a plumbing problem. The solution is to securely anchor your pipes; especially near the valves, so the abrupt change in pressure as the water is started and stopped will be dissipated into the structure of the walls, rather than allowing the pipes to vibrate against them.
Dec 23, 2010 | Admiral Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Pulsating water in the hot water cycle
id be curious as to the age of this machine, because the newer models have what teh call adaptive water temp sensors that will optimize the water temp automatically.. your hot water may be "too hot" and your cold can be "too cold" and the valve corrects to a preset temp. this sounds like whats happening
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
