I own a Philips plasma panel,model number 42 PF9966/79. Approximately 30 mins after warm up an effect like someone is using a green spray paint can, works from the outside of the picture towards the centre until no picture is viewable..changing channels and returning alleviates the problem for a minute or so..then the cycle repeats itself but with shorter viewing times until this is no longer possible.My tech says probably have to change the guts of the TV beginning with the 'Y buffer boards' until problem is solved....Any thoughts would be greatly appreciated while I still have hair!
if you can do component testing and or if you want to spend about $20-$30 in components , you could replace all the electrolytic capacitors , voltage regulators/zener diode and check/replace bad resistors.
or yes , start the board replace process
Was this helpful?
Yes
No
Popular Solutions for Philips 42FD9932 42 in. Plasma
the television wont power up and a red light flashes 6x repetedly, if I remove the power and try...
(More)
the television wont power up and a red light flashes 6x repetedly, if I remove the power and try again it will power up
I bought a Philips 42FD9932 42in Plasma TV about 3 years ago. recently when I turn on the TV about...
(More)
I bought a Philips 42FD9932 42in Plasma TV about 3 years ago. recently when I turn on the TV about half hour, the TV started blink and it will get back to normal after few seconds, then few munites later started again. Now even no any pictures shown on TV (totally black even can't get the channel #). I'd appreciate it if you have a solution including possible parts names or model #, Thanks
