Question about Insignia - 450W 5.1-Ch. A/V Home Theater Receiver NS-AV511
Receiver keeps going to standby
My system was working fine until I turned the sub woofer up at which time the receiver shut off and the stand by light started blinking. Now it will not stay on. Only powers up for a second or two then goes back to standby with the light blinking
2 Suggested Answers
  • 36 Answers
SOURCE: Receiver stays on standby mode
Receiver either just stuck or held or having problem in amplifier output area.
Try to unplug it from AC outlet for couple of minutes and replug back in and power up, if works, fine and if does not, take it to local repair shop as it might requires some parts replacement in amplifier out area.
Posted on Feb 10, 2009
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
It will not power on
henrylshelt,
Your sub should turn on into standby mode when plugged into AC power without being attached to the receiver. If it does not follow the list below. If it does, the sub needs a signal from your receiver via either by line-level (RCA) or the speaker wires to turn on out of standby. Ensure that the cable or wires going to your sub is in fact sending a signal while the receiver is on. To Test, (speaker wires) hook up a different known working speaker; (line-level) Some receivers have a menu option to turn the LFE output on and off, ensure that it is on and producing a signal.
Diagnose the problem:
1) Remove all wiring to/from the unit except for the AC plug (use a different known working AC outlet), will it turn on? If so the other outlet is not working.
2) Remove the woofer, does the amp have a fuse that need to be changed? Change the fuse. If it blows again after replacing and turning back on, the speaker is blown; go to #4.
3) Unplug the woofer from the amp, does it turn on? If so, go to #4.
4) The sub need to be serviced. http://www.jbl.com/EN-US/Support/Pages/SupportOverView.aspx
-Hope this helps, Chris.
Aug 29, 2010 | JBL PSW-D112 Speaker
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
I lost my remote control and I want to turn on my sub woofer manually through my receiver. How do I turn on my sub woofer.
Perhaps I misunderstand the question.
Depends on the Sub. Most powered subs will go into standby mode in the prolonged absence of a signal. Then they wake up when you play something.
Or are you saying you need to Enable the Sub, as in setup? Remote probably required for anything like that.
Dec 02, 2009 | Aiwa AV-D58 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Onkyo TX-SV525 Receiver subwoofer pre out no sound
Yes turing on the "A" speaker is required for the Onkyo, but that only turns on the 2 front speakers in the "A" speaker jacks.
You may also need to check and see if the Onkyo has a menu selection in the setup menu that will turn on the sub woofer output on the back of the receiver.
I have seen on countless occasions where people just have a hard time finding that sub woofer option on their receiver.
I do not have the manuals for this Onkyo, so I can not tell you the exact way to find it.
I have been repairing surround receivers since they have been on the market and beleive me, you are not alone in this situation.
Sometimes it seems like you need a Phd. in programming or something similar just to firgure out how to set one of these up.
The solution should be in your owners manual, with the problem then being, just where in the manual. Go slowly thru it paying the closest attention to anything about set up procedures.
I have also seen at times where the setup for the sub-woofer is not listed as sub-woofer, but as "LFE" (low frequency effect) . So keep your eyes open for that.
something else, your sub woofer may have an auto turn on. That means it will only turn on if it detects an input signal. Make sure yo uhave the volume up enough on the receiver to trigger that auto turn on if yours has one.
I would like to have been more help, but without the manuals I can only give you general type thngs to look for. These type of receivers are all so different and all so complicated to operate. The days of just turning on a stereo, selecting your source and turning up the volume seem to be over.
Let me know if you need any more assistance from me.
Dave
p.s. Very nice system you have, when you get the Kef working I think you are going to just love this system. and Onkyo has the best quality receivers in their price range.
Jun 27, 2008 | Onkyo TX-SV525 Receiver
Shuts off everytime i turn it up pass 4.
Speaker wire contact with each other is the problem. Check the back of ALL SIX speakers including sub-woofer. You should find wires contacting each other. Fix that and your problem will be solved.
Barry Scholles
Strasburg, OH
Sep 04, 2007 | Yamaha HTR-5240 Receiver
Insignia - 450W 5.1-Ch. A/V Home Theater Receiver NS-AV511 Logo
29 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
