Question about JBL BP1200.1 Car Audio Amplifier
JBL 86280-0w011 Car amplifier
I need a wiring diagram to connect a JBL 86280-0w011 car amp. Where can I find one, please?
  • 33 Answers
SOURCE: jbl car amplifier
hi,
you can download the manual here http://url2it.com/gme
if you need further help please reply back.
Posted on Jun 15, 2008
repairman78
  • 18 Answers
SOURCE: amplifier problem
try this it may help do you have a frend that you could swap amps with just to test (put your amp in a working system to check yor amp) as it could be a number of things it could be no out put from the head unit or a break in the rca cables or dare i say it but the amp could be blown it may even be speaker cable from amp to sub or the remote not working have fun !
Posted on Jan 07, 2009
  • 51 Answers
SOURCE: jbl gto 75.4 right channel not working
Hi
It's rare that 2 channels will fail simultaneously, are you sending 4 signals to the amp or just 2?
If you are sending just 2, perhaps the problem lies before the amp in the cabling to it, or the output from the headunit. If you are sending 4 signals then there may be a fuse in the amp that drives 2 channels out of the 4. Of course this may be the case should you just be sending 2 signals.
Posted on Mar 28, 2009
  • 122 Answers
SOURCE: i got a stock ford JBL amp with no wiring diagram
ok on most amps there are two sets of wire ports one for speakers & one for +12v,grd & 12v remote start if you look over each port it will say what port is for what wire if it is in a connector it gets slightly more complecated what you do is with a vm check from wire to chassis ground [like seat bolts] 12v with key off when you cet power isolate wire then turn key on till radio comes on then do the same test for 12v isolate that will be remote start then turn key off &check from the first wire to other wire for ground to find speaker wires connect a regular peace of wire to chassis grd & touch the wires you will here the speaker pop be sure not to hold the wire on long cause it will blow the speaker
Posted on Jun 04, 2009
Devsta
  • 68 Answers
SOURCE: Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Posted on Aug 05, 2009
I am having a JBL GTO 601.1 amp and Pioneer SPL 2000 DVC Sub. Can the amp be bridged. How should I Connect the terminals, series or parallel.
I believe series.....hook a wire to the positive of one voice coil to the negative of the other.....with the remaining two wire that to the amp.....check on google to see if your amp is able to be bridged.....Most of the time on the bottom of the amp there will be a diagram or the the two outer speaker outs on the amp itself....let me knoe if this helps you...thanks
Mar 23, 2012 | JBL Car Audio & Video
Car amp
I cannot understand the problem , do you need the diagrams
Apr 10, 2008 | Car Audio & Video
My jbl gto75.4 red light is staying on and no sound what can the problem be.
check the cord from deck to amp when you trun on the deck it should go from red to green some of amps you do need to run a blue wire from deck to amp. that the remot wire.. so you don,t need it going bysingle from the rca cable... I hope this help you out ty
Feb 19, 2011 | JBL GTO75.4 Car Audio Amplifier
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Disconecting the sound
the amp kicks out bcuz your pulling to much power out of the amp or your positive wire is to small in gauge.
Jun 17, 2009 | Car Audio & Video
I got a stock ford JBL amp with no wiring diagram i need to know what wires are what i have tryed to test for the power wirer but no luck.
Jun 04, 2009 | JBL BP1200.1 Car Audio Amplifier
JBL CS60.2 Car Amp is fitted to new sterio but stays on 247 regardless weather the car is on/off or even when sterio is off... so stays on during the night ¬¬
The blue wire to your amp (remote signal wire) needs to be connected to the red power lead for your deck. Right now it sounds like you are connected to constant power on your signal wire.
Apr 04, 2009 | JBL CS60.2 Car Amp
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
JBL BP1200.1 Car Audio Amplifier Logo
51 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
