Question about Sharp AF-S120FX Air Conditioner
Evaporator sensor display En and stop work, i search the this error in internet and said is a malfucntion of evaporator sensor i change it and work for 2 days and now i display it again and doing again sorry bad english.
    New Friend:
evaporator sensor - 9dce5e1f-a9fd-4ac6-b2d6-263b1db730e4.jpgSpraying Clorox in the vent area is not going to work. I tried that to no avail. You will have to disassemble the unit ( remove the outer case) to get at the circulating fan which is completely incased in stryo foam. I will attach a photo. Please note that I have removed the upper have of the fan inclosure .
Posted on Sep 22, 2013
Every day I have some dyslexic out fit take the place of my chosen Home & Search page. put it in Add-On Every day -sometimes twice a day.
It can be frustrating when a program changes your default search provider, especially if the provider is changed without your permission. But you can stop this from happening. When a program such as an add-on or toolbar suggests changing your default search provider, Internet Explorer displays a dialog box that lets you decide whether to keep or change your current default provider.
If you want Internet Explorer to keep your default search provider and not prompt you again, select the Prevent programs from suggesting changes to my default search provider check box in the dialog box that appears when a program suggests a change.
You can also do the same thing by following these steps:
  1. Open Internet Explorer by clicking the Start button . In the search box, type Internet Explorer, and then, in the list of results, click Internet Explorer.
  2. Click the Tools button, and then click Manage Add-ons.
  3. In Manage Add-ons, under Add-on types, click Search Providers.
  4. Toward the bottom of the screen, select the Prevent programs from suggesting changes to my default search provider check box, and then click Close.
ref:
How do prevent programs from changing my default search provider Windows...
How to Fix Browser Settings Changed By Malware or Other Programs
I would also run a program called COMBOFIX by bleeping computers to help remove infections.
http://www.bleepingcomputer.com/download/combofix
Feb 29, 2016 | Computers & Internet
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
I need set up file...
> need setup file
For what program? Adobe? Half Life? WinAmp? Linux? Windows? Vista?
What hardware? PC? Mac?
Feb 17, 2011 | Computers & Internet
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Right Side temp is going high, evaporator frosted
Did you change the orfice tube? The screen may well plugged up causing this
May 31, 2010 | Samsung Refrigerators
Say ci intermitent in the display and sometimes stop cooling
The error code should be C1 and this would mean that the return air sensor is either disconnected or faulty. The sensor is clipped onto the fin plates of the evaporator where the air is drawn into the evap.
Oct 28, 2009 | LG Art Cool LA1000PR Air Conditioner
Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
May 09, 2008 | Kenmore 54701 Dehumidifier
Sharp AF-S120FX Air Conditioner Logo
97 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
