Question about Daewoo Refrigerators
Daewoo frs 2411 ial problem
Hi anyone got the answer to this : my Daewoo is extremely hot on the wall between the fridge part and freezer. the freezer is not cold enough and the stuff is just about frozen, but not enough. the speed thingy is flashing all the time really fast. anyone have an idea whats wrong or how to fix this problem. Any help at all would be great
  • 183 Answers
SOURCE: need help
With this model it suffers with the evaporator freezing up, try to defrost overnight with the doors open, restart the following day and it should start to work ok within 24hrs. Regards Advisor
Posted on Sep 01, 2007
fridgetech
  • 473 Answers
SOURCE: Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Posted on Oct 05, 2007
SOURCE: Daewoo FRS-2031IAL instruction manual
Hold down the [ice make lock] and then the [lock] button simultaneously for 3 seconds. It took me a couple of attempts but I got there in the end (the manual mentions holding them down at the same time).
Posted on Apr 21, 2009
projdoc
  • 2237 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
  • 4793 Answers
SOURCE: fridge not cold enough and freezer not producing ice cubes
how does any tradesman(person) know how much its gonna cost before they even look at it.....
i would suggest you call a small,family run,electrical shop.
they have a reputation to uphold......
Posted on Jul 21, 2010
DAEWOO FRS - 2411 IAL COMPRESSOR
go ahead but on wrong site fixya doesnt sell products
Jul 27, 2017 | Daewoo Cars & Trucks
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Have a daewoo frs u20dcb side by side fridge an the centre post dividing fridge and freezer is getting very hot is this a problem
There is a fixed thermostat behind the panel in the freezer. It might be bad. Get a new thermostat fro your model refrigerator at an appliance parts store and replace it. Only two wires attach to it. It is an easy job.
Apr 29, 2014 | Refrigerators
Daewoo frs-u20dai service manual
my Daewoo side by side fridge freezer FRS-U2ODAI keeps leeking water from underneath and it says on screen DEODORIZER and FUZZY can u help
Apr 03, 2012 | Refrigerators
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
Hello, I have a daevoo fridge/freezer \model FRS-2031 IAL I need to plumb it into the water supply for the ice and cool water but do not have the user manual. Can you assist please
You can download the detailed user manual from the following link.( http://www.nodevice.com/user_manual/daewoo/refrigerator_or_air_conditioner/frs-2031ial.html ).Enter the verification code shown into the box and click download.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Daewoo Refrigerators Experts
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
