Question about Kitchen Ranges
Whirlpool range model rf198lxms Burners stay on High heat
Burners do not cycle from high tow for temp control
Amigaman
  • 248 Answers
SOURCE: Whirlpool electric range top burners
Probably have to replace the infinite switches. These are the controls you turn for the burners.
Posted on Nov 18, 2007
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
  • 132 Answers
SOURCE: burner heating element stays on high-cannot
there is a thermostat element beside every burner
i think it need to be changed.
thank you
Posted on Jun 08, 2009
GE TrueTemp range JBP30W0B1WW — 3 of 4 burners stay on HIGH even when set to low/medium.
as there is no make /model listed only a guess would be the switches
Dec 26, 2015 | Kitchen Ranges
Troubleshooting electrical stove
Infinite switch, it's not cycling internal contacts are welded together, make sure control it's set on low, if the heat element. stays red hot, replace control (inf. switch).
Dec 23, 2009 | Kitchen Ranges
Burner heating element stays on high-cannot
thank you
Jun 08, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
Ge profile electric cook top 30in. all burners stay on high temperture
the controls for the burners are reastats, if they all are only heating on high and you cannot lower the temp the switche are bad
Apr 30, 2008 | Kitchen Ranges
Unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Nov 29, 2007 | Whirlpool SF367 Gas Kitchen Range
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
