Question about Garden
M200aul beckett pump
Where can I find a Beckett m200aul fountain pump?
dragonsthatk
  • 547 Answers
SOURCE: GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Posted on Feb 12, 2009
pondking
  • 21 Answers
SOURCE: beckett large pond pump
if by large you mean one that likes the photo you have picture it is a lost cause as it it epoxy encased and unrepairable. If thats the case buy a pondmaster or atlantic pump. proven performers that are repairable and very good warranties
Posted on Mar 23, 2009
  • 10865 Answers
SOURCE: Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
Posted on May 02, 2009
  • 7 Answers
SOURCE: Where can I find a replacement impeller for a 10
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Posted on Sep 27, 2009
SOURCE: Beckett # W1150 WTRFall/Str Pump: Our pump will run for an hour or so, and then it s...
This same symptom happened to me.Check the impeller, if you can pull it out or it just sloshes around in the well housing, then the impeller lock has come out of it's place. Simply pull off the outer intake grill, then twist off the outlet housing. Now you can see that white notched washer and how it must be seated and aligned. Once seated in place use a small screwdriver to turn and lock it in. Now you will see your impeller shaft is no longer loose.
Posted on Jul 30, 2010
How to remove a pressed on impeller
Is it pressed on using a keyway on the impeller shaft or is it simply a pressed interference fit?
Jul 21, 2014 | Beckett Corporation Beckett Professional...
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
