Question about HMF Kawasaki Mule 600/610 08-11 Swamp Exhaust
Is there a relay preventing my steering from turning
Wheels turn right, but will not turn left
When you put the key in the ignition the key will not turn. The steering is locked
try turning the wheel hard to the left or hard to the right while turning the key, The wheel is probably just locked.
Mar 24, 2015 | 2002 Dodge Caravan
Why ignition won't turn
By far the most likely reason that one can't turn the key in the ignition is because the car was parked with the wheels turned. There is a security feature that locks the steering when the key is removed to prevent a thief from driving the car.
When the car is parked with the front wheels other than strait, the weight of the car will cause the wheels to try to straiten, If this engages the steering lock pressure is put on the ignition switch.
To start the car, look to see what direction the wheels are pointing. grasp the steering wheel and turn it TOWARD the direction the wheels are turning and now start the car.
Other causes may include wrong key, damaged ignition or other causes that may require a professional.
Aug 16, 2014 | 2009 Nissan Versa
What is wrong with my car
That sounds very much like you broke off a tie rod end. Check to see if the front wheels agree with each other. Turn the steering far left, verify both front wheels are turned left. Turn the steering far right, verify both wheels are turned right. If the front wheels don't agree, DO NOT attempt to drive the car - have it towed somewhere or have someone repair the steering where it sits.
Aug 04, 2014 | 1999 Buick Park Avenue
What is wrong with my ignition,when I put the key in it won't turn ?
I have seen this on many vehicles. It is entirely possible that when you last parked and shut it off you had the steering wheel turned to the left or right rather than centered straight ahead. The power steering was assisting with holding it in that position until you shut it off. At that time power assist stopped and the wheel is resting firmly against the theft lock mechanism. Grasp the steering wheel firmly and if your front wheels are pointed to the left then force the steering wheel to the left a bit more and turn the key will holding the wheel, if front wheels are to the pointing to the right then force the steering wheel to the right and turn the key. Try NOT to turn off the ignition with the wheels not pointed straight.
Jun 18, 2014 | 1A Auto Parts Vehicle Parts & Accessories
Ignition key
It is possible that your steering wheel is in a full turn position causing tension to the locking bar that prevents movement.
Check your wheels and see if they are turned to the left or right. If so, try turning them FURTHER the same direction to unlock the steering. Good luck.
Dec 07, 2013 | 2006 Ford Fusion
BMW X5 2007 key is stuck in the ignition and the car will not start. We already tried charging the batteries and still would not release the key.
OMG, I want to thank you all for your information. I was looking for any information I could find on how to get the key out of the ignition on my BMW 330 CI. My key would not come out of the ignition. I would have to put the car in park, turn off the key and then push the knob more into the Park position. I thought the coin blog would be to easy. I went outside, removed the ashtray and low and behold, there is a quarter in there. I was so excited. The key now comes out without and issues. Thanks again for your information.
Nov 04, 2012 | 2007 BMW X5 3.0si SAV
Ignition key won't turn
Try turning the key while jerking the wheel left and right and depressing the brake pedal. If that won't work try another key.
Oct 17, 2017 | 2002 GMC Sierra 1500
Steering hard to turn to the left like power steering is out but turns ok to the right. Checked power steering fluid. It is OK
bad steering problems,,your steering rack most likely,but,have you recently been stuck in ditch? when wheels are straight, look at front of car when parked. do wheels look funny? one going one way, and the other going the other? may be alignment. is it leaking any fluid on either side of the front of the car? drivers side? passenger side? if it's not out of alignment,,,wheels out of alignment,,the steering rack is the problem. it may be faulty. if not leaking fluid,it may still be bad. first i would make a visual test look under the vehicle while someone turned the steering wheel to right and left while car is in park,emergency brake on!! look at the steering arms while they turn the steering wheel from right to left. no fluid leaks? any resistance in turning the wheel? any leaks,if so,go to leak and repair with steering line replacement.no leaks? suspect a bad steering rack. hope this helps and thank you for choosing fixya.com i love to volunteer
Dec 04, 2010 | 2000 Pontiac Grand Prix
Steering problems
The Obvious: You have something broken in the front end. What to do: get yourself under there and take a look at everything. Anything that looks amiss probably is. Jack both front wheels off the ground... lie down where the vehicle can't fall on you and have someone turn the wheels back and forth. Look and see what's preventing travel. If it's that bad, it shouldn't be that hard to find!
Feb 14, 2009 | 1998 Jeep Cherokee
HMF Kawasaki Mule 600/610 08-11 Swamp Exhaust Logo
62 people viewed this question
Top HMF Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you a HMF Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
