Hi, i wrote a program with 4 variables. they all prompt and enter correctly but i get an error that reads "variable or flash application is locked, protected or archived" the "goto" option takes me to the first line of my equation in my program. I my program looks kind of like this:
:km()
:prgm
:prompt db
:prompt e
:.577*e*db*pi......store k
:disp k
:end program
any ideas?
Im new to programming so i dont understand what the issue is. Im following a you tube tutorial on programming an 83... so maybe there are some differences in the two languages....
Thanks
I agree with the previous solution and would like to add if you declare your variables using the local command then they will only reside in that program.
:prgm
:local db, e, plus other variable used in your program with a comma to separate them.
:prompt
And I think what the above solution is saying is to :Disp "k",k would work better.
I hope you used the Ti commands and not the ones you spell out on your listing, if so you might want to check them too. The store command I can understand why you typed it out.
I like the fact you want to program so remember fixYa to help you develop your programming.
Languages are different. But I suspect that the name you have given to your program has already been assigned to a previous one. Give another name and retry.
Hope it helps.
You may get
Memory Error when you try to access an archived variables. From the other hand
Memory Error message is displayed if there is not enough free RAM to access the
archived variables. For correcting Memory Error message use the 2ND then MEM to check RAM free size and 2ND then
VAR-LINK to determine the size of the archived variables that you want to
access. As the third step for correcting this problem deleting unnecessary variable
from RAM and archiving large variables or programs. By the definition, the RAM
free size must be larger than the archived variables
