Question about Kitchen Ranges
Onity #CA 22 remote reader control board
No power getting to electric door latch. No power coming from board to door/latch wire. Already installed new transformer. Board or card reader???
5 Suggested Answers
ardmax
  • 155 Answers
SOURCE: where is the card reader connector on the mother board
You can find a detailed manual here
http://www.intel.com/support/motherboards/desktop/d865glc/sb/cs-008973.htm
If your card reader has a USB type connector you can use the connector J9F1 or J9H1.
Let me know if you need further help.
Posted on Oct 29, 2007
huuum
  • 750 Answers
SOURCE: problem with oven door latch
Hello noahsark,
Welcome to Fixya
You said, after Hurricane Ike, when the electricity came back on, you noticed the oven door latch was in lock position and the door would not close because it would hit the door latch. You guess the door latch locked on it's own with the surge of electricity but did not lock the door in place. And that you have never used the self cleaning oven, so the door latch has never been used. How can I get the latch to unlock itself?
Was the range get under water?
If so there may be some shorts in it or faulty electronic parts!
Try turning the range off and then turning the power off at the breaker for 5 minutes.
This is should reset the system in an electronic range.
If it works , great .
If not you may need service to diagnose your electronic problem.
Let me know that it works!!!!!
Send me the Brand and mode;l number.
Please remember to leave a rating when you finish.
Huuum
Posted on Oct 03, 2008
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Posted on Dec 16, 2008
Rear hatch door of2004 toyota sienna xle will not open electrically
Operation of the power back door is controlled by the power back door ECU and the power back door drive unit. Either or both units could be defective.
If the I/P indicator is falsely on, there could be a problem with the body ECU or as a result of failed communication with the power back door ECU and the power back door drive unit.
Jun 24, 2017 | 2004 Toyota Sienna
Appears when initiating self cleaning. Can clear code, but door locked Does not begin self cleaning cycle.
Check this procedure to solve it:
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to
step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.Here is the control board to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | KitchenAid KERC506HBS Electric Kitchen...
E1 F5 code after self clean cycle. its been 12 hours and wont unlock and still says code
Hi.
E1 and F5 (F5-E1) means that the Self clean latch will not lock. The problem is usually fixed replacing the door latch. If the door latch is working, check wiring to door latch. The control module causing the error is not very common but possible. If the latch and wiring are OK, check control board.
Here troubleshooting from manual:
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
Here parts and diagrams: arrow_link.gif KERC507EAL1
Regards.
Ginko
Jun 18, 2011 | KitchenAid KERC507 Electric Kitchen Range
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
Neather rear electric side door will operate with the door switchs at the doors but operate o k with the console buttons up front or remote buttons. how do i fix ?
if i were you i would check all fuses for blown ones. once you have checked for blown fuses i would check the wiring with a volt meter to insure that it is fully functional the wiring on the doors will be easy to access if you cut into the wire coupling coming out of the frame.
Feb 08, 2011 | 2002 Chrysler Town & Country
There is a code f9 on my ditigal range and the oven door will not open and the stove does not work
Hi. this is a door latch failure code. Kindly, check the wiring that is linking the door latch mechanism, to the main control board. If the wiring is connected and the contacts are well, this will lead to a failed door latch mechanism. I would advise to test before purchasing a new latch assembly. Once you have exposed the door latch assembly, use the procedure below to test.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing. If there is continuity, this will confirm that the main control board has failed. Control board failure, in this case, is highly unlikely, but possible.
Nov 29, 2009 | Amana Kitchen Ranges
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
ELECTRIC DOOR LOCKS ONLY LOCK SOME TIMES
if you hit the lock button a couple times, will it finally lock?
If so, then you will need to take door cover off and lube up the connectors as they probably got corroded.
Aug 14, 2009 | 2000 Ford F350 Super Duty Super Cab
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
Broken door handle - 2001 Nissan Quest SE
first you van order parts at discount from tascafordparts.com.
quest & mecrury villager are the same vehicle made at the same assembly plant. good luck to all. If you were in detroit area, I wold help you.
Trim Panel —Sliding Door Removal
  1. Remove the sliding door trim panel finish panel.
532ac84.gif 2. Remove the sliding door trim panel 2965fbe.gif Latch Remote Control —Sliding Door Removal
  1. Remove the rear sliding door trim panel. For additional information, refer to Section 501-05 .
  1. Position the watershield aside.
  1. If equipped, disconnect the sliding door power door lock actuator electrical connector.
  1. NOTE: Mark the position of the sliding door rear latch cable adjusting bracket before removing the bolt.
  2. Disconnect the sliding door rear latch cable.
  3. Remove the bolt.
  4. Remove the sliding door rear latch cable adjusting bracket from the latch remote control.
  5. Disconnect the sliding door rear latch cable from the latch remote control.
  1. Remove the 4 sliding door front latch bolts.
NOTE: If necessary, transfer parts to the new sliding door latch remote control.
Remove the sliding door latch remote control.
  1. Remove the bolts.
  1. Remove the sliding door latch remote control.
Handle —Exterior, Sliding Door Removal
  1. Remove the sliding door latch remote control. For additional information, refer to Latch Remote Control—Sliding Door .
  1. Remove the sliding door exterior handle.
    1. Remove the nuts.
Mar 08, 2009 | 2001 Nissan Quest
Kitchen Ranges Logo
863 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
