Question about Dishwashers
Lamona dishwasher HJA 8362 Problem Hi,,All the lights are on and the machine won't start. Please help....is it the filter? Thanks
3 Suggested Answers
SOURCE: user manual for lamona dishwasher
Hi my salt level indecator light stays on even when I have filled it with salt! please help anyone
Thanks Rose
Posted on Mar 10, 2011
sodeep
  • 3267 Answers
SOURCE: How do I change or
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Posted on Jul 07, 2011
    Lamona hja 8514
    You have an internal pump which is not accessible without uninstalling the appliance, however instead of using drain block have you tried a proper appliance cleaner and cleaning the connection under the sink as this is where most smells come from and not the machine themselves
    Apr 07, 2014 | Washing Machines
    Howdens dishwasher hja8362
    The water in the machine is normal there is nearly always 1/2 a lit to a lit of water when a load is finished. Also if you dishwasher is out of warranty there Re a few things you can do one go buy a $20 voltmeter and unscrew the face plate and see if anything is lose mine hade a wire come lose and made the hole thing misbehave.
    Jan 26, 2014 | Dishwashers
    Lamona hja8630
    How do I remove the integrated door af a lamona hja 8630
    Jan 01, 2014 | Dishwashers
    Lamona Washing Machine HJA 8514 Half way through a
    (no promises but try this!)
    I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
    Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Jul 27, 2011 | Washing Machines
    How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • Jul 07, 2011 | Dishwashers
    User manual for lamona dishwasher HJA 8630
    Thanks Rose
    Dec 24, 2010 | Dishwashers
    Lamona dishwasher from Howdens. E1 code
    we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
    Feb 21, 2010 | Dishwashers
    Dishwashers Logo
    19 people viewed this question
    Top Dishwashers Experts
