Question about Motorola Mobility V557 Cellular Phone
V557 motorola phone display
My display went out. I can dial with it but i can't see anything .
  • 2 more comments
  • Anonymous Nov 08, 2007
    Inside and outside displays quit. Removed and replaced battery and sim card multiple times. Still no luck. No obvious damage to the phone and no abuse of the phone either.
  • sassygurl04 Nov 20, 2007
    Display screen is out on my phone. Replaced battery and reinserted SIM card. Anyone know how to fix it? Thanks
  • Anonymous Feb 26, 2008
    I have had the same issues with my v557. The outside display and inside display went blank at the same time. The key pad lights up and I can still hear all the sounds but can't see a thing!!
  • Anonymous May 31, 2008
    I turned my phone on and off several time. As well as opening and closing the phone. Nothing seems to work
I had the same problem and suspected that it was the button malfunctioning. I could not use my address book, so I tore the phone apart. I discovered a burned copper thread on the circuit board behind the button. This is probably intentional on the part of Motorola... cheaping around for higher initial profit and then we just have to buy new phones. The circuit can't handle the screen for long period of time. Seems to be a design problem. I am just going to use the parts from the v559 to repair a charge port on my old v557 and switch the chip back.
Posted on Oct 01, 2008
Look at just below the screen and you will see a little stub sticking out. when you close the phone up, the stub pushes into a small hole, just above the rt soft key.
When it goes inside this hole, the screen shuts off. There is a problem in in this area. If you have your phone turned on, you can take a small object and push into this hole and your screen comes on. At lease mine did. Problem, once I closed the phone and open it back up, I had to push in the hole again to get a picture. I even sprayed dust remover but with no luck.. I may need to get a new phone.
Posted on Mar 04, 2008
Try turning the mobile off and then
insert the SIm turn the mobile ON
make sure the battery is ON
Posted on Jan 27, 2008
My motorola v557 cell phone doesn't light up. how
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 12, 2010 | Motorola Mobility V557 Cellular Phone
Motorola V557 Black Screen
Hello! The blank screen issue with your V557, could be the LCD Module itself or even the connectivity of the cables inside. Usually the interference is the cables within the handset. It garbles the screen to either a black or white color and can sometimes distort the entire display. This can be a definite sign of hardware problems.
Now without a screen to see, how would you able to even use the handset? Your device is indeed an older model and the features that it offers are not vast. It has no expandable memory to store any pics or movies or music and it barely supports blue-tooth.
In my opinion, with the hardware issues u are facing are great enough to prohibit you from using blue-tooth to transfer your media.
Thanks.
Apr 20, 2009 | Motorola Mobility V557 Cellular Phone
No texting on motorola v557
most of the problem like this is from the cell provider or line provider ask them to activate the outgiong text.... Probably you need to bring your cellphone to them to test the result of activating the text outgoing.... Hope this will help you alot,,...
Jun 15, 2008 | Motorola Mobility V557 Cellular Phone
Phone screen is too dim.
YOU NEED A NEW LCD I SEE THEM ON EBAY FOR $15 SHIPPED. BUT IT WON'T BE EASY TO REPLACE.
Apr 04, 2008 | Motorola Mobility V557 Cellular Phone
Motorola v557
Hello. Your mic actually went bad from either liquid damage or a small bump. You need to have the mic either replaced at a motorola service center. Or you can do it yourself. It is quite easy. Just buy the mic from ebay for any old v series motorola phone v300 v400 v500, they are all the same. and just install it yourself. If you dont have a local service center in your area, cant find the part or cant do it yourself, look in my profile and i am sure we can help you out. If you found this helpful, give me a rating!
Jan 28, 2008 | Motorola Mobility V557 Cellular Phone
V557
u need 2 change the display lcd
Sep 12, 2007 | Motorola Mobility V557 Cellular Phone
V557
use ear phone to receive calls
check with the vendor if under warenty replace the mobile
Aug 31, 2007 | Motorola Mobility V557 Cellular Phone
Motorola Mobility V557 Cellular Phone Logo
284 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
